Name that bolt!?
Old Jul 9, 2012 | 01:32 AM
tracdogg2's Avatar
tracdogg2
The changeover to metric started in 78 but only on newly designed parts. When the Malibu changed in 78 it was a completely different car except for engine and trans and related parts. So all the body bolts were metric and the engine bolts were SAE. R4 air compressors were assembled and adjusted with metric but mounted to the engine with SAE.
There was nothing new on the 78 and 79 so no metric bolts. In 80 they went with the new Dana diff. New spring mounting design so it got metric bolts even though the Dana internal bolts were still SAE. 84 was a new car but, same as the Malibu, only the engine had SAE.
The blue color designated metric threads so they could be easily identified. The metric changover cost us(mechanics) thousands of dollars in new tool purchases. American metric bolts are not the same size as Japanese metric. We use 5.5, 8, 10, 13, 15, 18, 21, 23. They use 6, 8, 10, 12, 14, 17, 19 mm.
Mike
Old Jul 9, 2012 | 11:27 AM
80malibu's Avatar
80malibu
Gave it a bath to illustrate the color painted on this factory installed bolt.
Old Jul 9, 2012 | 12:11 PM
bpassmore's Avatar
bpassmore
Trackdogg is right on. anything new was coded blue for the metric, to aide in the assembly. Going through the change as a mechanic then was an adventure having to deal with the two systems. I still have new blue bolts removed from cars of that era when we changed or added accessories; been a long time.
Old Jul 9, 2012 | 01:16 PM
Paul L's Avatar
Paul L
Mike
Thanks for the blue explanation. I just learned something new.
Old Jul 9, 2012 | 04:15 PM
TurboStitchCW's Avatar
TurboStitchCW
a friend of mine was driving his 79 Vette last thursday and the driver's side trailing arm failed....bolt that attaches the spring to the trailing arm pulled straight through the t/a...twisted and torn metal. Luckily he was a few feet from his parking space...still had to get a town, but he wasn't charged for it since it wasn't very far.
Old Jul 9, 2012 | 06:28 PM
Jim Shea's Avatar
Jim Shea
For several years while GM was converting a lot of their nuts and bolts to metric, suppliers were instructed to use a blue dye on the metric fasteners.
I think that the blue dye requirement was buried in a purchase specification so that the dye requirement could be eliminated by updating the spec and not having to change a million nut and bolt drawings.
Interesting fact, the Saginaw power gear housing had tapped bosses for the mounting bolts to screw into. Whatever the metric equivalent for the mounting bolts, the metric bolt would strip out a gear housing pad that was a conventional thread. I don't remember what the exact sizes were. But Saginaw never converted the gear housing to metric in fear that using the wrong bolts could cause a safety problem.
Jim
Old Jul 17, 2012 | 03:11 PM
80malibu's Avatar
80malibu
Back to work at the dealership, one of the boys ordered the GM part-no. replacement bolts, part #11514112 and this is what you get, at a horendous price too I might add.
Old Jul 21, 2012 | 02:05 AM
80malibu's Avatar
80malibu
Replaced the bolts.
Old Jul 21, 2012 | 08:28 AM
...Roger...'s Avatar
...Roger...
Hopefully not over $5 a piece.
http://parts.nalleygmc.com/products/.../11514112.html
Old Jul 21, 2012 | 11:44 AM
mapman's Avatar
mapman
Originally Posted by paul 74
Could be metric but why is it blue? Corporate blue was an engine color.
Purpose of the blue paint was to identify a fastener as metric to the assembly line workers. The early 80's were transition years to metric fasteners. Most parts retained imperial bolts but as parts were redesigned (e.g. 1980 front bumper) the fasteners were transitioned to metric.
Years ago I asked Dave McLellan about the blue finish on some of the fasteners on my 1980. I thought it was some sort of protective covering. He related the blue finish was to id the fastener as metric.
Old Jul 21, 2012 | 12:02 PM
mapman's Avatar
mapman
The three rear bolts retaining the rear spring to the differential carrier are metric. The longer two bolts are Hex M12 x 1.75 x 90 (10.9 PC). The shorter bolt is Hex M12 x 1.75 x 30.
BTW the driver's side bolt on my 1980 was also broken off. I removed the entire batwing and had a machinist remove the remaining bolt shaft. The machinist then installed heli-coils in all three bolt holes (I personally don't like the idea of tightening steel bolts into aluminum threads).
Old Jul 23, 2012 | 01:08 PM
80malibu's Avatar
80malibu
Originally Posted by ...Roger...
Well, up here in the Great White North, GM dealer cost is $8.00 ea with a suggested list of $17.00 ea. Coulda ordered the kit from Corvette Central for $10.75 and shipping etc, but hey, I'm sitting in front of a GM parts ordering system all day so what the heck.
