Name that bolt!?
Old Jul 7, 2012 | 05:57 PM
80malibu's Avatar
80malibu
Default Name that bolt!?
My son and I went out for a cruise today in the Corvette (1980), and as I was turning into a parking lot, average concrete apron/driveway, I heard a CRACK! Like a gunshot, this was while car would be mildly flexing across the "ramp" as usual. We drove down the street about a block and this broken bolt fell out from underneath the car. Would have been about 3" long unbroken and has a rating of 10.9 with a letter "A" on the head, an 18mm socket fits the bolt. It's dirty, like typical grease and dirt with the hint of Corp. Blue paint. I'll have to wait a while to get it up on a lift to look properly. Car didn't do anything weird after, like nothing happened Any ideas ?
Old Jul 7, 2012 | 06:05 PM
...Roger...'s Avatar
...Roger...
Harmonic balancer center bolt maybe.
Old Jul 7, 2012 | 06:34 PM
boeing46's Avatar
boeing46
Because of the color I would make a clueless guess that it may be an exhaust manifold bolt. By process of elimination what was the last work done on the engine? It looks broken at the end. Is the car making any funny noises?
Old Jul 7, 2012 | 06:52 PM
BB72's Avatar
BB72
Thats probably your rear spring bolt. The one that bolts the plate(under the spring) to the differential.
Old Jul 7, 2012 | 07:00 PM
...Roger...
It seems like it should be an engine bolt , metric and blue.
Old Jul 7, 2012 | 07:36 PM
80malibu's Avatar
80malibu
It has me stymied, corp. blue but filthy the whole length, I cleaned it and it's worn blue paint the whole length as well. If it's like my 1980 Malibu, every nut and bolt on the car is metric except the engine. The blue throws me but I'm thinking rear suspension.
Old Jul 7, 2012 | 07:59 PM
80malibu's Avatar
80malibu
*WINNER*
Had a crawl under the car and sure enough, LH rear corner bolt of the center mount plate of the leaf spring. With enough hangin' out to get a grip on.
Thanks a bunch for the guesses fellas!
Old Jul 7, 2012 | 08:02 PM
Mooser's Avatar
Mooser
I could be totally wrong but I believe the rear suspension hardware stayed imperial right up thru 82. Have a quick look at the 4 bolts holding the spring on though just in case
Apparently I was totally wrong
18mm head, maybe check the #4 body mount (seems long though)
Mooser
What a difference 3 minutes makes
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I recall my 80 pickup had metric bolts for the airconditioning compressor mounting. those were the only metric bolts (and blue too) on that truck
Old Jul 7, 2012 | 09:02 PM
80malibu's Avatar
80malibu
The Malibu is mostly metric, the body is for sure. driveline was std. The 10.9 is the metric strength indicator vs. the imperial "hash" marks.
This brings up another question, what is the consensus regarding using stainless fasteners on the underside of the car? Stainless resists corrosion and is strong, but is it too brittle for the "flexie" bits of the car?
Old Jul 7, 2012 | 09:50 PM
Mooser's Avatar
Mooser
Your hard pressed to find a stainless bolt that would meet the low end of a grade 5 steel bolt.
Most are maxed out under the min tensile requirements for grade 5. (around 100 vs 120 ksi or there abouts)
There are special military and aircraft level stainless but $$$$$$$$$$$$
Mooser
Old Jul 7, 2012 | 11:07 PM
80malibu's Avatar
80malibu
Mooser
Kinda figured as much, thanks for the tip!
Old Jul 7, 2012 | 11:36 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
After purchase I drove my white79 from Rhode Island to Chicago and found this when I got home
Glad the earlier years used FOUR bolts instead of 3!
Old Jul 8, 2012 | 01:25 AM
80malibu's Avatar
80malibu
Exactly the same broke on me today! That's the one...
Old Jul 8, 2012 | 08:44 AM
...Roger...
I don't remember those bolts being metric.
Old Jul 8, 2012 | 04:04 PM
KapsSA's Avatar
KapsSA
My 79 wasn't.
Maybe the 80-82s with the aluminum housing and "batwing?" mount were?
Old Jul 8, 2012 | 05:02 PM
...Roger...
My 79 wasn't.
I think your right about the 3 bolt mounts,for some reason I was thinking his was a 4 bolt. Heck I can't remember if the 80 had the batwing or not,getting old is hell.
To Name that bolt!?
Old Jul 8, 2012 | 05:53 PM
Paul L's Avatar
Paul L
Could be metric but why is it blue? Corporate blue was an engine color.
Old Jul 8, 2012 | 06:20 PM
...Roger...
That's what I was thinking but someone might have just painted it.
Old Jul 8, 2012 | 06:56 PM
Mark G's Avatar
Mark G
Maybe the same reason air conditioning adjusting bolt was blue, or the fan shroud nuts are greenish/blue. Maybe a different color of coating to prevent corrosion. There is black, which you see in the engine compartment, green, olive and there must be blue as well since I've seen it around. Not necessarily on the springs, but in the engine compartment.
