seat covers...self install or pay ?
Is it worth paying the money or is it better to do it yourself. I'd like to hear from some that have done it themselves. Would you do it again if you had to or farm it out. I'm leaning to do the self install.
We`ve never done Corvette seats yet, but I can`t imagine them being any more difficult than any others. If you do much of your own work, you should have no problem.
You must by the seat covers, seat foam and seat installation kit. (just use the sale code and you'll save 10 percent off on these items).
Repairs are extra and if you need any you will be contacted first.
But given the installation video, many people have successfully installed seat covers that never would have tried it before. On a C3 they really are not that hard. That is the good news..
Bad news is that if you send them in, the delay is about three weeks turn around time.
Willcox
I JUST finished doing my 1972.
Did foam + seat covers + door panels + carpet
http://s963.photobucket.com/albums/a...view=slideshow
Of everything, the carpet is the easiest
Door panels are next easiest
Seat covers are a lot of work.
You will spend 4 hours minimum on each seat
If you are handy; have good arm & hand strength and some ingenuity and like the feeling of accomplishing a project, then go for it.
Otherwise, it's worth $300 to $400 for the time & labor for the pair to not have to do it.
Trust me on this one.
Wilcox, great response. You guys are here to help, not just try and sell a service.
I guess I will do them myself. Save the extra money for something else like a new clock...
If it was easy to ship I would probably get Willcox to do them as thats where I plan on buying everything...just waiting on the new prices for the Al Knoch covers..hint hint.....
Thanks for the input.
If you are asking about the difficulty level of doing that job, it is about a 3 out of 10, IMO. You just need to be careful, make detail notes on where each wire retaining clip came from...and KEEP THEM, and not get frustrated to the point of doing damage to the new seat covers.
P.S. The wire clips are internal to the seats/covers. You can just cut the hog rings off with some good wire cutters. And you will need a cheap set of hog ring pliers to install the new ones.
I watched the Corvette America video and paused it at each step while installing the covers, it was not an easy job. I can see after a fashion once you get the little tricks down it would become easier. The second seat went easier than the first for me. It took my wife and I about 10 hours from removal of seats to installation of seats back in the car. Took lots of patience and time plus a very sore back from working on the garage floor. If you want to save time and money though, then go for it, just be prepared to be somewhat frustrated at times and tired but satisfied when it's done.
We'll be doing the seats in our '77 at home.
Adam
Because of my height, I dropped the driver's seat down a good bit and stuck with the old foam, removed the seat belt covers too....little extra clearance....the use of hog ring pliars is a waste, just use Zip ties,, easy as pie and you can adjust each one for appearance, I left the plastic as above in place between the covers and the foam, never a second's troubles....
i'ts about a 1 hour job/seat doing it my way.....
NEW foam gives you that show car look, overstuffed and plump/plush appearance, but it's a super PIA, especially if you don't do the plastic trick, I used just plain green garbage bag material, cut open to single layer....
I picked up on it while watching a guy who did custom show cars, and did a entire car for me, ~25 years ago, but I stopped by to watch and BS one day and got a seat foam/cover edjemakshun.....
