Stone dead !!
Old Jul 16, 2012 | 09:52 PM
Alex/plus's Avatar
Alex/plus
Default Stone dead !!
Okay guys, I tried starting my 78 L82 automatic yesterday and it was dead. Got out my multimeter and checked battery----tests perfect. Even though it didn't even make a click sound I purchased a new, reduction 8lb. starter for a 98 Chev 5.7 truck. Fit was great but needed 1/2 inch shorter bolts. I went to the starter first because I have been wanting to replace the old 20lb. hot start behemoth with a more modern efficient one.
Now I have my new starter installed but still no engagement and yes, I checked to see if I had it in park but when I turn the ignition key to start the interior courtesy lights and anything else blinks off.
What's next?..........Alex
Old Jul 16, 2012 | 10:32 PM
Aussie79's Avatar
Aussie79
You are describing a flat battery pretty well, reading volts on a battery tells you almost nothing, if you have it, test the specific gravity, if not then test the volts at the battery while you try and crank, if they drop below 9VDC while cranking then you most likely have a battery issue, if not then you have a huge short somewhere..........now where is that fire extinguisher?
Old Jul 16, 2012 | 11:08 PM
TimAT's Avatar
TimAT
Check the starter extension harness at the firewall connection. I'll bet the purple wire (and maybe one of the red ones) has melted the connector and the terminals.
Old Jul 17, 2012 | 06:40 AM
Alex/plus's Avatar
Alex/plus
Thanks guys,
I'll check the battery first and move on from there. Anyone else have ideas?
Old Jul 17, 2012 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alex/plus
...Anyone else have ideas?...
Got a good, clean, tight chassis ground at the battery?
Old Jul 17, 2012 | 01:22 PM
Alex/plus's Avatar
Alex/plus
Hi easy Mike,
Yes, I should have a good ground. Several years ago I cleaned that area and reattached with dilectric silicone.
Old Jul 17, 2012 | 01:37 PM
MelWff's Avatar
MelWff
dont forget the neutral safety switch! can you start in neutral or jump the switch and try
Old Jul 17, 2012 | 01:58 PM
c3corvette77's Avatar
c3corvette77
Do you have any power to the body of the car? Does the dome light come on when you open the door? If not dollars to donuts the problem is in the firewall connection top passenger side. Or a bad fusible link.
Old Jul 17, 2012 | 07:51 PM
Alex/plus's Avatar
Alex/plus
I have all interior lights but they all go out when I turn the key to start.
Old Jul 19, 2012 | 04:27 AM
zuendler's Avatar
zuendler
Measure the battery voltage during your attempt to start.
If it drops below 10V your battery is the problem.
If it keeps 12V but your lights go out you have a wiring problem.
To Stone dead !!
