Oil pressure gauge problem
Old Jul 18, 2012 | 11:09 PM
ksumt93's Avatar
ksumt93
Default Oil pressure gauge problem
My oil pressure gauge isn't working. I am thinking it is probably the sending unit. I think I have found the unit....just left of the distrubuter. My question is, is there an easier way to remove it than having to remove the entire distrubuter? I can't get a wrench on it due to lack of space between it and the firewall.
Other than that....has anyone seen any good posts on troubleshooting oil pressure guages.
Old Jul 18, 2012 | 11:28 PM
SIXFOOTER's Avatar
SIXFOOTER
Not a very tough circuit. Disconnect the wire from the sender, check the gauge, ground the wire, check the gauge. You should be able to get on the sender with a small pair of channel locks.
Old Jul 19, 2012 | 08:58 AM
7T1vette's Avatar
7T1vette
I don't have an '82 or that year's AIM...but I thought the sender for the later C3 years was located just above the oil filter pad.
Old Jul 19, 2012 | 10:56 AM
...Roger...'s Avatar
...Roger...
The 82 GM shop manual shows it in both places,probably due to the fact that 82s ,depending on the radio option, had an oil temp gauge also.
Old Jul 19, 2012 | 09:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Go to the oil pressure switch location and pull the wire off of it. The oil pressure gauge is a twin to the fuel gauge only with a thinner damping oil and a different face. The scale is exactly the same. 0- no oil pressure, 90 ohms is max.
If you pull the wire from the sender the pressure should to to max. If you ground this wire out it should to to 0. If you do this and the gauge works then the issue is in the sending unit.
Willcox Inc.
Old Jul 19, 2012 | 11:49 PM
ksumt93's Avatar
ksumt93
when I pull the wire it has three prongs. Why are there three and what is the procedure for grounding it to check the gauge?
To Oil pressure gauge problem
