Trailing arm washers
Old Jul 26, 2012 | 01:03 PM
jordan89's Avatar
jordan89
Default Trailing arm washers
Hi guys, so I installed the rear suspension and forgot to instal washers in the trailing arm bolt. My question is, does it have a locking washer on the nut side and a flat washer with a locking washer on the head side of the bolt? This is going to be a pain in the rear to do again.
Old Jul 26, 2012 | 02:01 PM
MelWff's Avatar
MelWff
the nut is a castle nut using a cotter pin and a flat washer on both sides
Old Jul 26, 2012 | 03:26 PM
Mooser's Avatar
Mooser
The replacement set I got had a thick flat washer and a lock washer (and castle nut)
I ended up putting flat washers on both sides (under bolt head and under the nut).
The washer under the head of the bolt will be to spread the load out (bolt shouldn't really turn during use) and there isn't that much side-pressure on the bolt (mostly shear)
Your probably OK to leave it out and just put the one flat under the nut.
That being said, now is the easiest it will ever be to take the bolt out and do it "right"
Mooser
Old Jul 26, 2012 | 04:43 PM
dariopop's Avatar
dariopop
Mooser
Old Jul 26, 2012 | 06:55 PM
jordan89's Avatar
jordan89
Mooser
I think I'm just going to go ahead and take the bolts out and do it right. I hope it really is easy to do right now. I might just go with the flat washer behind the head, and the locking nut behind the castle nut. I thought I was done with the rear suspension.
Another question: what size washer and nuts are required for it? I might just go get them after school and knock them out tomorrow.
Old Jul 26, 2012 | 07:49 PM
Mooser's Avatar
Mooser
Pretty sure they are 7/16 fine castle nuts.
Loose the lock washers and put a decent quality thick washer (not too thick, even a good quality regular washer would work) under the head, once you put the bolt back in, make sure the thread is fully exposed through the frame and decide what washer for the nut side.
Make up a wedge of wood and put it under the T/A where it enters the pocket. Lightly tap it in place by hand and then remove the bolt, it should help hold the position at least somewhat
Mooser
Old Jul 26, 2012 | 11:22 PM
jordan89's Avatar
jordan89
Mooser
That's what I was thinking about using to hold it in place. I'll let you guys know how it goes.
Old Jul 27, 2012 | 08:45 PM
jordan89's Avatar
jordan89
Well guys, I got the task done today. Unfortunately the driver side was a PITA. I got the passenger side done in about 30 minutes. The driver side arm twisted a bit, so I struggled to get the bolt back in. It sucks not having any help in situations like this.
Old Jul 27, 2012 | 08:50 PM
Mooser's Avatar
Mooser
I hear you on that one, sometimes spend almost as much time rigging something up to do it myself as it does to actually do it.
At least now you know it's the way GM wanted it and that little question in the back of your head of if it's OK or not can go away.
Old Jul 27, 2012 | 09:33 PM
jordan89's Avatar
jordan89
That's true. One more question. How tight should the nut be?
Old Jul 27, 2012 | 10:34 PM
Mooser's Avatar
Mooser
45-55 ft-lb, then to the next cotter pin hole
Also, they should be tightened with the suspension in the "loaded" position
Mooser
Old Jul 28, 2012 | 12:16 AM
jordan89's Avatar
jordan89
[QUOTE=Mooser;1581423683]45-55 ft-lb, then to the next cotter pin hole
How am I suppose to get a torque wrench on there? You're being lots of help Mooser and I really appreciate it.
Old Jul 28, 2012 | 08:41 AM
Mooser's Avatar
Mooser
Oh, you'll need to take the body off for that...
But if you insist on leaving the body on.
Method 1
put a 7/16 nut/bolt in a bench-vise and tighten it to around the 45 mark with the torque wrench and then use a long boxed end wrench to move it a little more and get the "feel" of how tight is should be and then go heavier on the car.
Method 2
Us an extension (basically a crows-foot but longer) and compensate on the torque setting.
(my set is about 3" long from center of bolt to center of the drive, with a 2' torque wrench (drive to where your hand is) will increase the torque about 5 ft/lb
Mooser
To Trailing arm washers
