Power door lock issue
Old Jul 29, 2012 | 08:39 AM
nearflack's Avatar
nearflack
Default Power door lock issue
1980 model, Power door locks werent working. I replaced driver side actuator both switches and harnesses. With driver side switch connected when i connect the switch on the right side the fuse blows. Anyone have an idea what causes this. New harness is properly wired, and both switches are new. The old swithes and harness didnt cause the fuse to blow but didnt operate the locks. Could I have gotten a bad switch or is something else cause the problem. All suggestions/ideas appreciated. I still have the right actuator to change but dont see how that is the probolem.
Old Jul 29, 2012 | 08:55 PM
SIXFOOTER's Avatar
SIXFOOTER
you have the black and orange wires crossed. Its confusing because the new pigtails have the same wire colors on the same pins, but they are supposed to be different left to right
Old Jul 30, 2012 | 06:32 AM
nearflack's Avatar
nearflack
So change orange to black on both doors? Traced it to the switches but didnt think about wring differently. With old ones back on fuse holds but only right side will unlock left side tries to but nothing when try to lock it! Thanks
Old Jul 30, 2012 | 01:46 PM
nearflack's Avatar
nearflack
well the changing black to orange and vice versa didtn work. Plugged in the switch on drivers side with no problem but when i plugged in the passenger side the fuse blew. No sure where to go now but I have plenthy to work on while waiting for any other suggestions. Thanks for all your help.
Old Jul 30, 2012 | 11:25 PM
SIXFOOTER's Avatar
SIXFOOTER
When I got my new pigtails the wire colors were the same on both pigtails. However, the same pin gets a different color wire on the left and right doors.
Check this out
Old Jul 31, 2012 | 09:52 AM
nearflack's Avatar
nearflack
Thanks for all you help. I am pretty dense when it comes to these diaghrams but think I can figure it out, if by no other means trial and error Fuses are cheap
To Power door lock issue
