speedo cable versus grommet help needed
Old Jul 29, 2012 | 02:16 PM
spf72's Avatar
spf72
Default speedo cable versus grommet help needed
What is the trick to getting the speedometer cable grommets over the end of the cable. I tried heating it but maybe not enough?
Old Jul 29, 2012 | 02:24 PM
gbvette62's Avatar
gbvette62
You need to put a slice in the grommet, with a razor blade or X-Acto knife. That's the only way I know of.
Old Jul 29, 2012 | 02:28 PM
spf72's Avatar
spf72
Thanks I had a razorblade all set but thought I should ask. I took off the original and that one isn't cut soit can be done.
Old Jul 29, 2012 | 03:17 PM
Alan 71's Avatar
Alan 71
Hi spf,
I've wondered about that too.
The cable and grommet are individual part numbers in the AIM which I believe means they came to St. Louis separately and were joined there.... but how?
Regards,
Alan
Old Jul 29, 2012 | 07:44 PM
StingrayLust's Avatar
StingrayLust
It is a tight fit, but it can be done. I used some variation of WD-40 and silicone spray lubricant on each part and then just pure muscle. I've done it twice and it takes me about a good 15 minutes of cussing, scraping my hand, and pure willpower to get the end into the rubber grommet.
I guess if you give up, a razorblade is a next best solution.
Old Jul 29, 2012 | 09:22 PM
M A Fry's Avatar
M A Fry
I used rubber grease and muscle. Took a bit of doing, but I got it.
Mark
p.s. I've got to do it again shortly as I have a complete new assembly to put into mine.
To speedo cable versus grommet help needed
