Single horn note
Old Aug 2, 2012 | 01:59 PM
CQRT's Avatar
CQRT
Default Single horn note
My `73 came with a single horn - - (that sounds like a bleating bovine in heat).
I did a search without success - - in a single horn car, was the horn a high or low note? (am guessing low)
thanks
Old Aug 2, 2012 | 03:15 PM
Shark Racer's Avatar
Shark Racer
Have you traced the wiring to verify that you're not missing a horn?
Old Aug 2, 2012 | 03:33 PM
CQRT's Avatar
CQRT
Yes- car only came with one . . two was an option.
Old Aug 2, 2012 | 03:39 PM
Alan 71's Avatar
Alan 71
Hi C,
When the change to one horn was made it was a low note.
Regards,
Alan
Old Aug 2, 2012 | 03:48 PM
CQRT's Avatar
CQRT
Originally Posted by Alan 71
Hi C,
Regards,
Alan
Thank you sir - - I had another 73 back in the day, but just couldn't remember.
thanks !
Old Aug 2, 2012 | 09:48 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
[QUOTE=CQRT;1581468473]My `73 came with a single horn - - (that sounds like a bleating bovine in heat).
My '72 only has one horn also. You described it perfectly.
Old Aug 2, 2012 | 11:42 PM
Vette5.5's Avatar
Vette5.5
Like most, don't use my horn often, but nice to have one that can be heard when needed. Quite easy to change out, or add another tone though, as done this a couple times. Careful how far you go, as my dad got a Buick off the lot years ago, that had a four tone horn option on it. Thing sounded like a circus parade. You could sure hear it though.
Old Aug 3, 2012 | 01:27 PM
Mgrad92's Avatar
Mgrad92
Being a musician, and having had to deal with replacing horns on my vette, I can tell you that there is more than one way to skin a cat. You basically want to use harmonious tones. Therefore, if you're not concerned with 100% authenticity, you can use various different tones and get something that sounds good. For instance, a C low and a high E work great. Or an E with the higher G works too. You could also get the C, E and G for the tri-tone. If you want to go all out, get the C, E, G and Bb (B flat) and you'll really make an enterance.
Good luck!
Old Aug 3, 2012 | 01:44 PM
Shark Racer
Good luck!
This is some awesome advice. Chords!
Old Aug 3, 2012 | 02:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...there is more than one way to skin a cat...
Please confirm no cats were skinned in the making of this thread.
Old Aug 3, 2012 | 02:49 PM
Mgrad92's Avatar
Mgrad92
I've always wondered about the origin of that phrase.
Who really needs to know more than one way to skin a cat?
And if you do, you're one sick puppy. (Pun intended)
Old Aug 3, 2012 | 03:18 PM
Easy Mike's Avatar
Easy Mike
...Who really needs to know more than one way to skin a cat?...
Old Aug 3, 2012 | 03:34 PM
80malibu's Avatar
80malibu
Checking my dusty old parts book Rev. 12-83, the list looks like this:
55-79 1892163 F note
55-70 1892164 A note
65-80 1892162 D note
76-79 1892164 A note
76-80 1892246 C note
76-77 1892247 F note
81-82 1892164 A note
81-82 1982246 C note
To Single horn note
