Powder coat removal
Old Aug 7, 2012 | 10:41 AM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Powder coat removal
What is the most efficient and non destructive way to remove powder coat from engine parts?
Old Aug 7, 2012 | 12:40 PM
7T1vette's Avatar
7T1vette
It depends on what you call 'non-destructive'. Walnut shell blasting will remove paint but not "damage" the metal. But, it may smooth the metal surface just a bit. Since you are going to paint it again, that shouldn't be a problem. Glass bead blasting will be quicker, but smooth the surface more. Sand blasting will actually etch the surface.
Or, you can use a chemical stripper. Lots more messy, though.
Old Aug 7, 2012 | 01:33 PM
wro87's Avatar
wro87
About the best way we have doen it is to use stripper and set it in a black plaqstic bag in the sun for a few hours. the spray gasket remover from Permatex worked ok. the bag keeps it from evaproating so quick and the heat from the sunn let is work a little better. we had to do it 3 times before we got it all off, I didn't want to use glass beads since it was real thin alumina.
Good Luck wro87
Old Aug 7, 2012 | 02:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dr L-88...
I'm watching to see if anyone has figured out a way to remove powder coating because I've not. The above two suggestions are great ideas for paint removal but for items that have been powder coated it won't work.
So here is a bump for you... hopefully there is someone else that has crossed that bridge.
IMHO,
Willcox
Old Aug 7, 2012 | 03:10 PM
Vette5.5's Avatar
Vette5.5
Gotta agree with "Wilcox" as done my share of blasting, and works well on hard surfaces, but not so good on soft surfaces like powder coat. Really depends on the temperatuture of the powder coat used, but a heat gun usually works on just about anything.
Old Aug 7, 2012 | 03:22 PM
oldalaskaman's Avatar
oldalaskaman
benco 17 paint stripper
permatex 80646 gasket remover.
hope this helps
Old Aug 7, 2012 | 04:18 PM
Shark Racer's Avatar
Shark Racer
Ask the guy I sold my 02 Corvette to. He managed to get a lot of powder coat off the wheels I had done after running them into a couple curbs.
Old Aug 7, 2012 | 05:25 PM
lvrpool32's Avatar
lvrpool32
The Permatex spray gasket remover works (not the brush on stuff...thats a different formula).In fact its how I stripped those magnesium Torq Thrusts without damaging the metal.
Nick
Old Aug 7, 2012 | 08:07 PM
0Willcox Corvette
Former Vendor
hope this helps
And this will eat through the powder coating???? If so, I'll be off to buy some tomorrow. I have some spindle supports that were powder coated and I want it off...
Old Aug 7, 2012 | 08:28 PM
Richard Cooper's Avatar
Richard Cooper
I use an Airplane Stripper made by Mar-hyde. You just brush it on the powder coating and let it sit for about 15-20 minutes and scrape it off. Sometimes you have to apply it a secont time, but it works very well.
Old Aug 7, 2012 | 08:46 PM
Steve's '73's Avatar
Steve's '73
http://www.eastwood.com/ew-powdercoa...ver-quart.html
Old Aug 7, 2012 | 09:52 PM
oldalaskaman
softens it and then brush or peel, needs to sit and soak a bit, dont breath it, you'll start seein funny, ask me how I know.:woohoo :
Old Aug 7, 2012 | 10:21 PM
Dr L-88's Avatar
Dr L-88
Originally Posted by lvrpool32
The Permatex spray gasket remover works (not the brush on stuff...thats a differentdifferent formula).In fact its how I stripped those magnesium Torq Thrusts without damaging the metal.
Nick
Apparently Permatex has discontinued their 80646 aerosol gasket remover. Must have some "good stuff" in it that EPA doesn't like.
Old Aug 7, 2012 | 10:24 PM
oldalaskaman
well darn them anyhow.
Old Aug 8, 2012 | 12:40 AM
0Willcox Corvette
Former Vendor
Funny.. I could use...
I'll give it a try... never to old to learn a new trick...
Old Aug 8, 2012 | 12:41 AM
0Willcox Corvette
Former Vendor
Okie.. I'll have to give this a try instead.. Thank you..
Old Aug 8, 2012 | 07:32 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I have used this several times successfully.
Old Aug 9, 2012 | 11:26 AM
boat196's Avatar
boat196
The company that I used for powder coating, used a oven to heat the parts to remove the powder coating. I don't know what temperature is required.
Bob
To Powder coat removal
