fuel sender sock
Old Aug 9, 2012 | 12:08 AM
cherokee2602's Avatar
cherokee2602
Default fuel sender sock
So I am trying to get the old 76 vette back in shape new brakes shocks new carb new u-joints but now I have a problem with it surging like it isnt getting enough fuel. I read about the fuel sock and ordered a new one with a gasket. I went to take the tank off and realized it had a liner. It worked fine meaning no leaks fuel guage worked but the strainer sock did look bad. My question is keep everything as is except change the sock and rubber lines? The liner looks fine and I hate putting more money into it my wife is about to kill me! I had to cut the mufflers off to get to the tank so there is another issue!! Any advice?
Old Aug 9, 2012 | 12:13 AM
cherokee2602
new fuel pump and fuel filter too!
Old Aug 9, 2012 | 12:26 AM
cherokee2602
Just read about inserting a spring in the sock? Do I need to do this?
Old Aug 9, 2012 | 12:53 AM
kdf1986's Avatar
kdf1986
I dont know about the spring in the sock. But I had a problem with my 73 with similar symptoms with surging and stalling. It turned out to be the sock. When I took it off it looked ok, but there must be some small obstruction that prevents gas from going through.
The spring does not sound like it could be too much money. I can understand why it would work and increase the surface area.
kdf
Old Aug 9, 2012 | 10:23 AM
cherokee2602
Yea I'm going to put the spring in the sock and hope the bladder holds up in the tank and call it good. Hopefully it will remedy the surging!
Old Aug 9, 2012 | 10:28 AM
oldalaskaman's Avatar
oldalaskaman
bladder should be fine, put the spring in, the year of your vette would be a big help
Old Aug 9, 2012 | 10:30 AM
cherokee2602
First thread has year 1976
Old Aug 9, 2012 | 10:35 AM
oldalaskaman
I missed that when I was taking a drink of coffee, probly saw it thru the bottom af the cup, 76 has an issue with the sock being to close to the bottom of the tank and plugging up. my 76 had it. the fix is to bend the tube ...just a bit...so its bout 3/8" from the bottom. there's actually a tech. paper from gm regarding this fix
its possible yours was already ...fixed...but it would be good to measure to be sure.
To fuel sender sock
