reverse engineering a/c
Old Aug 9, 2012 | 10:23 AM
oldalaskaman's Avatar
oldalaskaman
Default reverse engineering a/c
you folks that have converted to r134 and arent happy with it .
possibly have access to r12 or a variant
drain the r134
drain the r134 oil
change the drier
install r12 oil
pull a vacum
re-install r12
hope this helps
Old Aug 9, 2012 | 01:23 PM
manfroni's Avatar
manfroni
just had mine done yesterday. I found a NOS C6 compressor on Ebay for $125, bought new low pressure hose set, new office tube, 4 cans of R-12 from Ebay, and an o-ring set. The shop charged me $150.00 to flush the system, install the new parts and add 3 pounds of R-12. Ice cold air!!! I did the change over to the C4 blower when the system was apart, big difference is air volume. It was 92 degrees yesterday and I had to turn the fan down 2 clicks.
Old Aug 9, 2012 | 01:54 PM
oldalaskaman
excellent , many thanks.
Old Aug 9, 2012 | 02:04 PM
Shark Racer's Avatar
Shark Racer
FWIW, the tools that shops typically use to plumb to R12 have different adapters than R134a. A "true" R134a conversion will have these adapters attached. I believe in some cases they're self tapping and may damage the original connector.
(I can't remember where the ports are on the 78 off the top of my head - one of the fittings is typically on the accumulator/drier, so oldalaskaman's post may cover that one.)
Old Aug 9, 2012 | 03:34 PM
oldalaskaman
you dont have to change fittings, use the 134 gauges and fittings, your a/c fittings cant tell the difference and it will still look like a 134 system
btw, this is a DIY deal
Old Aug 9, 2012 | 03:41 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Did it 2 years ago....I like the idea of swapping out the blower fan which in my opinion is the weak link in the C3 HVAC system....other than allowing hot coolant to the heater core all the time.
Old Aug 9, 2012 | 04:34 PM
Shark Racer
Of course - I was just pointing it out because some people will have to rely on shops to do the evac and fill (especially with R12) and the shop may not be willing to do it if the fittings aren't correct for R12.
Old Aug 9, 2012 | 04:41 PM
oldalaskaman
you're right , not something a shop might do
Old Aug 9, 2012 | 05:29 PM
noonie's Avatar
noonie
It's illegal to go back to 12, once you have changed from it and also illegal to use the wrong fittings with the incorrect refrigerants.
I doubt a reputable shop would do it for you so you could save a couple bucks. Epa fines are pretty steep.
Old Aug 9, 2012 | 08:46 PM
oldalaskaman
yes, but my diy back to r12 blows ice cold
Old Aug 12, 2012 | 02:19 PM
lavery48's Avatar
lavery48
You say the Blower Motor in the C3's are a weak link in the system?? What do you replace it with ??
Old Aug 12, 2012 | 03:15 PM
oldalaskaman
havent done mine ...yet, but there are threads on here for upgrading to the C4 version
toward the bottom of this is a pic of the C4 fan spacer
http://api.viglink.com/api/click?for...13447996247663
To reverse engineering a/c
