Thinking about dying door panels
Old Aug 10, 2012 | 12:10 AM
cgc's Avatar
cgc
Default Thinking about dying door panels
Thinking about buying a pair of tan door panels I will need to dye them a dark blue. I have seen where others have done this but I didn't pay close attention. Is this a good decision or should I pay the price for aftermarket panels?
Old Aug 10, 2012 | 12:48 AM
7T1vette's Avatar
7T1vette
If the tan panels are factory originals, in good condition, and correct for your year and options, those would be the better choice, IMO. Some of the aftermarket panels don't fit that great.
Recoloring the door panels is pretty easy if you clean the parts well (detergent to get ALL the old oily protectant off of them), rinse them well to remove ALL detergent, dry them completely and then spray them with SEM liquid ColorCoat dye that you buy at a pro auto body paint supply store. They can mix it to the original interior code or match it to a piece you bring in (your other old parts are likely faded some). And you can buy a Pre-Val gas canister/bottle sprayer if you don't have spray equipment for less than $20 (including extra gas canisters). On dyed parts, that sprayer will do just as good as much more expensive equipment because the thin, high-pigment dye is so forgiving when sprayed. Two light, covering coats of SEM and your panels will look just like new, factory panels.
P.S. If you use rattle can dye, all bets are OFF....
Old Aug 10, 2012 | 01:46 AM
cgc's Avatar
cgc
Hi 7T1vette
Good to hear from you. I've been gone for over 2 years. When I was active on here you were one of my favorite posters. You always gave good help.
The panels are original and right for my car. I've only seen pics but they do look good and of course the seller says they are. I am going to contact the seller and ask for more pics especially the backs.
If I get them I'll be asking for more particulars on prep and spraying.
Old Aug 10, 2012 | 08:31 AM
Roco71's Avatar
Roco71
I took 7T1's advise and did just as he recommended and everything turned out great. I tried the spray cans the first time and not all of the cans matched. I ended up having the auto paint store mix a quart of SEM and redyeing everything.
Old Aug 10, 2012 | 12:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
SEM automotive interior dye. Clean, clean, clean, and clean again. I shot SEM dark blue over the black the PO had left me 20+ years ago. It's still there and still looks good.
Old Aug 10, 2012 | 12:35 PM
cgc's Avatar
cgc
Thanks to all of you guys. Your information is very encouraging. I contacted the seller this morning and if I can get pictures of the backside of the panels and if they look as good as the front side I am going to buy.
If I do purchase these panels I would need you guys to walk me through this process step-by-step. For one thing I will be wanting to know what particular cleaners I should use. I do have a large upright stationary air compressor and old siphon paint spray gun but I've never used it. I would love to learn how to paint maybe I can start with the door panels.
Old Aug 10, 2012 | 10:16 PM
John 65's Avatar
John 65
I used Dupont vinyl dye, mixed from the local body shop supply house. Sprayed my interior with a cheapo harbor freight touch up gun and it came out great. Good stuff.
Old Aug 10, 2012 | 11:51 PM
7T1vette's Avatar
7T1vette
I would still advise you to purchase the inexpensive Pre-Val bottle/gas sprayer and 2 or 3 extra gas canisters. So simple to use and the results are fantastic. You will need some lacquer thinner and a glass jar to purge the dye out of the sprayer each time you finish your paint session.
(The dye will stay inside the dye bottle, if you want to leave it there for a while. But, if there is much air in the bottle it will start to cure after a few hours. I tend to put in a bit more than I think I'll need, then pour the remainder back in the dye can when done. Then, put thinner in the bottle and spray the residual dye out on cardboard/newspapers.)
Old Aug 18, 2012 | 11:57 AM
cgc's Avatar
cgc
Default No soap
As I posted I asked for more pics.I also asked for maybe some help$$ on shipping. Got responce seller could do. Waited to get pics but never heard anymore from him. Found where seller had put panels back up for sale and they sold. I think someone got a great deal.
Thanks for all your help. Maybe next time.
To Thinking about dying door panels
