new owner
Old Aug 15, 2012 | 10:20 AM
debster's Avatar
debster
3rd Gear
Default new owner
Looking at a 1976 chevrolet corvette stingray in great shape. Person is asking $10,000, says it has around 80,000 miles and a new engine if I need it??????
Didn't open the hood to show us and said last time he had it on the road in 2003 it over heated?
Any thoughts or suggestions on price? Thanks.
Old Aug 15, 2012 | 11:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For $10K, it should be the best 76 you've ever seen. Any pics?
Old Aug 15, 2012 | 11:56 AM
jcloving's Avatar
jcloving
An overheating vette that has not run in 9 years is not worth 10k.
Old Aug 15, 2012 | 11:57 AM
keithinspace's Avatar
keithinspace
A car that was last on the road 9 years ago and, even then, had a serious problem with an unknown amount of residual damage...hmmmmm...
Doesn't sound like a $10k 1976 to me.
Doesn't sound like a $10k 1969 to me.
Old Aug 15, 2012 | 12:03 PM
debster's Avatar
debster
3rd Gear
No pictures, the body and interior were in great shape, however, without seeing under the hood to check for any wires chewed or any other damage, was hard to tell. I figured for $10,000 is should be turn key and drove right off the property? This would be my first time buying a corvette and I like the old body styles better....what would be a good price to off this person? Thanks for the advice!!!
Old Aug 15, 2012 | 12:54 PM
LS6 Motor's Avatar
LS6 Motor
$3000, and that's without looking at it. It's a 35 year old car which most likely will need everything. The owner is unrealistic with his asking price and would most likely be offended by that offer, but at the end of the day, it only worth what someone is willing to pay. I would keep looking, Fall is coming and price will go down, because people don't want to store them.
Old Aug 15, 2012 | 01:14 PM
debster's Avatar
debster
3rd Gear
Thank you...a friend suggested that I offer $6000 and nothing higher, I appreciate all the help!!!
Old Aug 15, 2012 | 04:34 PM
7T1vette's Avatar
7T1vette
If the car isn't running on its own power, it isn't worth $5K!
Old Aug 16, 2012 | 04:31 PM
my 76 ray's Avatar
my 76 ray
A new engine IF you need it??? I think he knows you need it. Why else would it not be driven for so long?
Old Aug 16, 2012 | 04:36 PM
AdamMeh's Avatar
AdamMeh
Not worth 10k and not worth 6k given the unknowns with it. Far better cars out there for less.
Adam
Old Aug 16, 2012 | 06:42 PM
jesse10886's Avatar
jesse10886
Three thousand is too generous if car doesn't run on its own power! Get a forum member to go with you to look at the next vette you want to buy it will save you allot of time and anger and over paying
Old Aug 16, 2012 | 06:44 PM
AdamMeh's Avatar
AdamMeh
Old Aug 16, 2012 | 07:44 PM
oldalaskaman's Avatar
oldalaskaman
Run
Old Aug 16, 2012 | 08:14 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Originally Posted by oldalaskaman
Run
Old Aug 16, 2012 | 08:27 PM
kdf1986's Avatar
kdf1986
I would offer the same advice as the other members. For $10k it should be in very good condition and drivable.
Last ran in 2003, and it overheated? Plus the owner has a new engine in case you need it? It sounds as if he may know you will need it. If it overheated it could have some engine damage. Not driving it in 9 years will cause other reliability problems.
For $10k these things should already be fixed.
kdf
Old Aug 16, 2012 | 09:47 PM
Jedi926's Avatar
Jedi926
For sure, do your due diligence with this car. Good luck.
Old Aug 16, 2012 | 09:49 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
offer him a buck two eighty.
Old Aug 17, 2012 | 10:22 AM
Easy Mike's Avatar
Easy Mike
...I figured for $10,000 is should be turn key and drove right off the property?...
I agree. You might want to consider passing on this car and keep looking.
To new owner
