Lock Actuator boot?
Old Sep 3, 2012 | 01:32 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Lock Actuator boot?
Where to find? This is for my 81, the boots on my lock actuators are in pretty bad shape
Old Sep 3, 2012 | 03:10 PM
C3-PO's Avatar
C3-PO
i don't know that they can be replaced without buying the whole actuator. since they are inside the door anyway .. just take some heavy duty plastic and tie wrap them off around the actuator. that should keep the moisture off them. otherwise it's off the the local pick-n-pull.
Old Sep 3, 2012 | 04:29 PM
SIXFOOTER's Avatar
SIXFOOTER
Yea, thats the way its looking. The boots I have are bad, but may have to do, I haven't removed them so they are mostly intact but would not survive removal. I'll probably leave them on there and just clean up the actuator a bit. With the new felts and seals the doors should be dry inside anyway.
To Lock Actuator boot?
