HELP! Engine code
Old Sep 4, 2012 | 09:34 PM
FatCat's Avatar
FatCat
Default HELP! Engine code
I have at this point narrowed my Corvette search and have a question.... Can anyone help me explain to the guy (through text) how to find the engine code on his Vette? He thinks it is numbers matching but not sure but glad to look for me since I am 7 hours away...THANKS!
Old Sep 4, 2012 | 10:23 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The engine stamp pad is located in front of the passenger side valve cover, on a ledge of the block where the cylinder head mates.
There are two components:
1. The engine stamp that includes a letter for the factory, a date code and an engine suffix code.
2. The VIN derivative stamp that includes a portion of the VIN that should be embossed on a metal plate and riveted to the A pillar post, driver side.
Numbers matching is a meaningless term. The above should at least help you begin determining whether or not the car has the original engine. More scrutiny will be required to arrive at such a conclusion.
Old Sep 4, 2012 | 10:30 PM
FatCat's Avatar
FatCat
Thanks for the information but please elaborate on the "numbers matching is meaningless"? I have never had a vette and really want to make a smart buy. I do want one that is all original within reason.
Old Sep 4, 2012 | 10:35 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
If you want to make a smart buy, I suggest having someone knowledgeable with your specific year look at the car. I'm sure there are many here on the forum that would extend a hand. Post where the car is located and maybe someone will chime in.
EDIT - I see you may have already tried this route. You'll find that "numbers matching" is a highly debated term on the forums. What you are doing is smart - verify that the engine is original to the car by matching the pad stamp to the titled VIN and the VIN on the drivers side pillar.
If you are interested in factory-correct, I would recommend you look into NCRS. They have plenty of info to help educate you on purchasing a car that is built towards originality vs. one that is modified.
Old Sep 4, 2012 | 10:42 PM
FatCat's Avatar
FatCat
I did try that over the weekend but didn't get any hits... Bummer!
Old Sep 4, 2012 | 10:44 PM
FatCat's Avatar
FatCat
The car is about 6 hours away! I do have a lot of pictures and it looks like a good deal for the money..
Thanks for your help.
Old Sep 4, 2012 | 10:46 PM
LeMans Pete
Feel free to post pictures of the car on the forum and the $$$. You will receive more criticism than complements, but the information will still be useful.
Old Sep 4, 2012 | 10:50 PM
FatCat's Avatar
FatCat
I will up load them now... I am open to getting criticism or knowledge... That is why I joined having never owned a Vette...
Old Sep 4, 2012 | 10:58 PM
FatCat's Avatar
FatCat
I plan to restore the door panels!! HAHA
Fire away!!!
Old Sep 4, 2012 | 10:59 PM
FatCat's Avatar
FatCat
I hope nobody beats me to it but I am at $4500.00 on it..
Old Sep 4, 2012 | 11:03 PM
vettebuyer6369's Avatar
vettebuyer6369
Here's some pictures to help a bit: 1. a typical engine pad, front side of passenger head. Contains VIN derivative and assembly code. This is painted over in engine orange. Most are cleaned off and are bare. 2. A block casting date code. 3. A block part number. 4. A transmission case with VIN.
The first picture is a number that "matches." The VIN derivative matches the title/ body VIN. However, it might mean the engine is original, or it might mean the block is restamped. The second number on the pad includes codes that tell you where the block was produced, the date and the engine option.
The second and third pictures are numbers that can be "correct" but do not "match" anything. The casting date needs to be appropriate to the build date of the car (and the configuration of the numbers) and the serial is a correct part number block for that model car... but could be from any car.
Finally, the trans case does have a VIN that will match the car VIN.
Hope this helps.
Old Sep 4, 2012 | 11:05 PM
Mike Ward's Avatar
Mike Ward
At that price and looking at the amount of modifications under the hood and elsewhere, I wouldn't worry about it being the orignal engine or not.
Old Sep 4, 2012 | 11:07 PM
vettebuyer6369
That engine compartment is awful, missing everything. Id be surprised if the numbers matched. Wrong wheels. Awful home made door panels. Rough looking car. Why do you want this particular car? The price?
Old Sep 4, 2012 | 11:10 PM
FatCat's Avatar
FatCat
Thanks Vettebuyer5869! Hey Mike Ward! I am ignorant when it comes to this but could you help me understand the "Mods" better? I just like the color and the pipes! HAHAHA
Old Sep 4, 2012 | 11:16 PM
Mike Ward's Avatar
Mike Ward
Virtually everything that can be seen on the engine - valve covers, carb, air cleaner, complete ignition system etc. etc. is aftermarket stuff and obviously the exhaust system. None of this increases or maintains the value of the car.
Old Sep 4, 2012 | 11:17 PM
vettebuyer6369
The mods are the carb, intake, yellow wires, distributor, valve covers and air cleaner. All very cheap replacements. Lots of factory stuff gone and the rest is very crusty.
Old Sep 4, 2012 | 11:24 PM
FatCat's Avatar
FatCat
OH! So because of the mods, it doesn't matter because it can never be original again? That would make sense...
To HELP! Engine code
Old Sep 4, 2012 | 11:26 PM
FatCat's Avatar
FatCat
I did just notice the engine is running in the picture.... I see the fan is blurred..
Old Sep 4, 2012 | 11:30 PM
FatCat's Avatar
FatCat
Are the pipes a good thing or no?
Old Sep 4, 2012 | 11:43 PM
FatCat's Avatar
FatCat
Sorry, I missed this earlier! I like the year, color and the price... Talk to me, educate me, show me where I am going wrong....I have a limited budget to buy one...
