Estimate on repairs
Old Sep 6, 2012 | 04:11 PM
JohnNC's Avatar
JohnNC
Default Estimate on repairs
Car is in Arizona i`m in N.C.
Mike V. here on the forum was nice enough
to check out a `69 Conv. for me.
Its like I thought an unrestored car with leaks.
58k original miles.
Anyway appox. to repair leaks at valve covers- steering box,
maybe rear main seal- I know most of this is labor. Typical
low miles car that wasn`t driven much and is now leaking.
If I wasn`t getting a good deal I wouldn`t bother.
Thanks,
John
Old Sep 7, 2012 | 10:46 AM
lvmyvt76's Avatar
lvmyvt76
a lot will depend on where you are getting it repaired at. Some shops charge $45/hr and some specialty shops charge $75/hr.. Can you do any repairs yourself, that will save a lot.
Old Sep 7, 2012 | 10:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Call some shops in your area, tell them what you want to do, and get estimates.
Old Sep 7, 2012 | 11:01 AM
Marlin's Avatar
Marlin
Valve cover should not be to bad if you get good gaskets and don't over torque the bolts.
Steering box, is this a number matching restore project or get it fixed to drive? If restoring then yea you can get rebuild kits and go that route. If driving then get a Rack&Pin or a jeep steering box.
Rear main I would not touch unless it was just flowing out or you are pulling the motor for a rebuild.
If those are the only problems with the car sounds like its in good shape. As far as pricing that will vary a LOT, esp with a older car like this. Best to either do it yourself or find someone on these forums that lives near you to do it as side work.
Old Sep 7, 2012 | 11:26 AM
LastC3AZ's Avatar
LastC3AZ
Give Mark a call at Vintage Iron .... he's in Scottsdale ... and can probably assist with shipping ......
http://www.vintageironandrestoration.com/
Old Sep 7, 2012 | 02:18 PM
7T1vette's Avatar
7T1vette
Arizona is a BIG state. Where is the car? That might narrow down where to have it repaired.
Old Sep 7, 2012 | 02:54 PM
CQRT's Avatar
CQRT
It's up in Havasu and needs to get to the Carolinas . . I think he's simply trying to figure out what his total cost of acquisition will be - -a local forum member has taken a good long look at the car.
John- I'd guess those items will cost less than a grand . . transport would probably be a grand on an open trailer- double that for enclosed.
Old Sep 7, 2012 | 06:57 PM
7T1vette's Avatar
7T1vette
Or, if it's driveable, he could spend $600 on gas and an extra $20 for leaked oil.
(I'd opt for having it shipped.)
Old Sep 7, 2012 | 07:56 PM
JohnNC's Avatar
JohnNC
Skip that one.
I bought a very nice `72 in AZ that CQRT checked out for me.
Fresh rebuild engine, trans. fairly new paint 87k miles. Interior needs alittle tlc.
John
Old Sep 7, 2012 | 07:59 PM
JohnNC's Avatar
JohnNC
Old Sep 7, 2012 | 08:25 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Very nice looking '72, I hope it goes well for you.
Regards
Roy
Old Sep 7, 2012 | 09:32 PM
Indiancreek's Avatar
Indiancreek
If that's all it needs, the repairs shouldn't be all that bad. Around here maybe $450 to $550.
To Estimate on repairs
