Flex Plate
Old Sep 9, 2012 | 05:54 PM
mk8035's Avatar
mk8035
Default Flex Plate
Well i just dont know. I have spent so much money on my car my wife is going to kill me one day. And it is still just sitting there all apart.
Got some supposedly some killer 350 engine in the car.
Well ripped off again (i hope not)
Anyway i shimmed starter it wouldn't engage the flex plate. As i was starting it i noticed that the flex plate was wobbling. Going to take engine out. When i was under the car i checked one bolt connected to the torque converter it was lose. **** what a great mechanic i had.
Should i take the engine out still or tighten the bolts on the Converter and use locktite?
Old Sep 9, 2012 | 06:10 PM
jnb5101's Avatar
jnb5101
if the flexplate was wobbling, the bolts to the crank may also be loose.
Old Sep 9, 2012 | 06:27 PM
mk8035's Avatar
mk8035
Default Flex Plate
So should just tighten the bolts or pull the motor. My mechanic just put it the motor in.When it did run witch wasn't long in neutral it sounded great. When put in gear it sounded like crap?
Old Sep 9, 2012 | 07:32 PM
Roco71's Avatar
Roco71
Just slide the transmission back a few inches or drop it. A lot easier than pulling the engine.
Old Sep 9, 2012 | 08:39 PM
'75's Avatar
'75
I would start by taking out the torque converter bolts and see if the flex plate still wobbles or feels loose and go from there.
Old Sep 10, 2012 | 08:15 AM
Roco71's Avatar
Roco71
About 15 minute fix if that's problem.
Old Sep 10, 2012 | 09:43 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
You're not having much luck, eh Bud? Sorry Dude.
Hope things work out for you.
Les
Old Sep 10, 2012 | 09:49 AM
mk8035's Avatar
mk8035
Cant quit it is now personal
To Flex Plate
