PowerWindows
Old Sep 11, 2012 | 07:18 AM
mk8035's Avatar
mk8035
Default PowerWindows
I am totally rewiring the car. And i haven't gotten to the windows yet, I have a problem with the passengers side window it is stuck in the down position. Any body have any tricks to get it up for the time being?
Old Sep 11, 2012 | 10:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Depends on the problem. Is it the switch or the motor? If you suspect the switch is the culprit, connect the passenger's plug to the driver's switch and try it.
Old Sep 11, 2012 | 10:11 AM
mk8035's Avatar
mk8035
Default Power Windows
I cut the wires at the motor. Car is completely gutted redoing all. That motor was working. Can i just run it to the battery to get it up.
Old Sep 11, 2012 | 10:26 AM
Mashman's Avatar
Mashman
Yes.
Ground goes to the motor case, and the positive goes to one of the terminals. One of the terminals will make it go up, and the other down.
Old Sep 11, 2012 | 10:28 AM
MrJlr's Avatar
MrJlr
Originally Posted by Mashman
Yes.
Best Answer !!!
Old Sep 11, 2012 | 10:34 AM
mk8035's Avatar
mk8035
Old Sep 11, 2012 | 10:56 AM
mk8035's Avatar
mk8035
Well that didnt work all the motor did was click.
Old Sep 11, 2012 | 12:01 PM
jaki30's Avatar
jaki30
Default DC Motor
I was under the impression that the two power leads on the connector to the motor carry (-) ground and (+) DC. The window switch reverses the polarity for the motor to drive up or down.
Old Sep 11, 2012 | 01:23 PM
mrvette's Avatar
mrvette
RONG!!! window sw puts +12 to one or the other terminal.....
one is up, other is down.....
Old Sep 11, 2012 | 01:44 PM
mk8035's Avatar
mk8035
Ok so how do i get it to go up?
Old Sep 11, 2012 | 03:29 PM
SIXFOOTER's Avatar
SIXFOOTER
pull up on the glass and bump it with power at the same time.
Old Sep 11, 2012 | 03:42 PM
mk8035's Avatar
mk8035
I will give it a shot
Old Sep 22, 2012 | 10:25 AM
mk8035's Avatar
mk8035
Ok window stuck down nothing works to get it up. Rewiring total car. OK Window motor is grounded to the door frame??? The window counsel switch has three wires total coming out of it. Two go to the power window motor so i can assume that the black third wire is the power?
To PowerWindows
