Buildsheet?
Old Sep 11, 2012 | 10:58 AM
Factor's Avatar
Factor
Default Buildsheet?
Hi Guys,
Do 69 corvettes actually have a paper buildsheet somewhere in the car?
Thanks,
Ron
Old Sep 11, 2012 | 11:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes and no. It isn't actually in the car. A copy of the Corvette Order was glued to the top left corner of the fuel tank at the factory. This document has become known as the tank sticker.
After 40+ years, your tank sticker may or may not still be there.
You might be able to peek around the rubber fuel collar with a good light source and see if you see something.
Good luck.
Old Sep 11, 2012 | 03:31 PM
Alan 71's Avatar
Alan 71
Hi Ron,
This is from a 71 but will give you an idea of what Mike described.
Regards,
Alan
You can sometimes see it by looking through the gas door opening and past the rubber boot on the filler neck.
Resist touching it if it's there until you drop the tank. The paper is VERYVERYVERY fragile at this point.
Old Sep 11, 2012 | 04:01 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Found mine on my 77 but was Un readable and was only about 35% there.
But I did find it.
Got it by taking the spare down and getting my hand on top of the tank. Was a chore to get to with tank in the car. But I got it.
Good luck.
Old Sep 11, 2012 | 07:31 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Ron
If you find it on the tank, it will be on the driver side. Mine was glued on so heavily that I just dusted it off, took lots of 3MB pictures and covered it with a plastic sheet and duct tape. It belongs there.
Old Sep 12, 2012 | 06:57 AM
rovers2000's Avatar
rovers2000
how long did they use the tank sticker? i have an 81 I got from my parents who owned the car since 1992 and have never modified the car. Woud the 81 still have a tank sticker?
Old Sep 12, 2012 | 08:57 AM
Factor's Avatar
Factor
WOW...so cool....i didnt think corvettes had this. I got my paper buildsheet from my 1970 chevelle...which I think is the coolest thing to have!
if I still have mine it would be icing on the cake, if not, the mice enjoyed it!
Old Sep 12, 2012 | 09:18 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by rovers2000
...how long did they use the tank sticker?...
All C3s had them.
...Woud the 81 still have a tank sticker?...
Yes, but there might be an easier way to do things. If your car was assembled at St. Louis, go here http://www.corvetteactioncenter.com/...x.php?cmd=area and see if you can obtain a copy of the original dealer invoice for your 81. The invoice has everything the build sheet would show, plus prices and other information not on the build sheet.
If your car was assembled at Bowling Green, contact the National Corvette Museum and see if they have your build sheet. https://store.corvettemuseum.com/ser...buildsheet.asp
To Buildsheet?
