Well today I decided to charge my ac system on my 82. Bought one of those AC Pro pull the trigger and watch the needle deals which did work but have a couple of questions. How can you tell the high pressure switch is bad? Because after the compressor is running for about 20 seconds it starts to turn on and off like you're flipping a light switch as fast as you can. When I jumper from the high press. switch to the compressor it runs fine and it actually puts out not ice cold air but pretty cold. Then next question when I had compressor out of the car I plugged the holes on both the compressor and the lines and did not tip it over so no oil would rub out. Thinking there was enough oil in there when the compressor was running it was very hot to the touch and sounded like rocks rolling around in there so I went to Advance Auto Parts and bought APG 150 oil and added the 3 oz. but didn't make a difference on the sound. So can anyone help here?
Since you state you removed the compressor, did you evacuate the system before recharging?
The R4 compressor does not use a high pressure sensor but it does use the cycling switch which I found out was bad. No I didn't evacuate the system, don't have the equipment. Took the charge and was putting out cold air, don't know how long it will last though. Thanks for the youtube link.
These compressors don't like too much oil. It's almost as bad as no oil and will effect the cooling capability. Did the trigger thing have oil in it too? Have you replaced the dryer? One thing I've learned is the condensors in the older cars are serial flow, meaining it's one long tube bent many times and the air flows in what's essentially a straight line. If there's any kind of blockage, your cooling is effected. You can replace these relatively inexpensively (I've seen them for less than $75) with a parallel flow condensor which is supposed to greatly improve efficiency. I'll be doing that to mine soon...
That three oz can of PAG150 only has one oz of oil in it the rest is 134A. So I wouldn't worry about too much oil at this point.
I'm guessing that this was an R-12 system converted to 134A. If that is the case and you don't know if all the mineral oil was flushed from the system the PAG oil could cause problems with the residual mineral oil and ultimately cause compressor failure. You would be better off adding Ester oil which is compatible with both Pag and mineral.
Not evacuating the system may or may not cause you an issue.
Definitely better to evacuate, not doing it will at least cause some loss of effiency.
