Signal Lights
Old Sep 22, 2012 | 01:53 PM
vaughn007's Avatar
vaughn007
Default Signal Lights
Today my signal lights on the driver side stopped flashing. Both front and back light up and thats it.
I went to the parts store and purchased a new flasher. I installed the new flasher and still not working, only the passenger side lights flash.
Does anyone here have an idea where i should be looking next to solve this issue?
Would like to hear from you if so.
Thanks,
007
Old Sep 22, 2012 | 04:38 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Have you done anything like installed LED's?
Old Sep 22, 2012 | 05:36 PM
vaughn007's Avatar
vaughn007
No, i haven't installed LED's. Have never had the lenses off.
Old Sep 22, 2012 | 07:05 PM
AdamMeh's Avatar
AdamMeh
When you turn on your emergency flashers do they all work?
Old Sep 22, 2012 | 07:32 PM
my 76 ray's Avatar
my 76 ray
Also check your side marker lights. I believe they all contribute to the draw required to make the flasher work.
Old Sep 22, 2012 | 10:56 PM
vaughn007's Avatar
vaughn007
SIGH!
I just tried my emergency lights.... they didn't work!!!
To make matters worse, now i have no signal lights at all. My vette is now not drivable and that sucks big time as the weather is beautiful!!
HELP PLEASE.
007
Old Sep 23, 2012 | 12:21 AM
AdamMeh's Avatar
AdamMeh
You'll need a wiring diagram and start tracing wires back from the lights until you reach power. That will tell you what section the problem is in. It's possible that it's in the column blinker switch.
Need more information to really help you. What year is your car? Headlights working? Tail lights working? brake lights working? park lights working? Is it just the blinkers that are not working? Blinker indicators in the dash working but the outside lights are not? etc...
Old Sep 23, 2012 | 12:31 AM
MAC 72's Avatar
MAC 72
Cruising
I know this may sound silly, but on some of my old GM cars and trucks, the bulb itself was bad and after it was replaced the flashers worked again. You should try that inexpensive way first. It couldn't hurt, right?
Old Sep 24, 2012 | 05:23 PM
vaughn007's Avatar
vaughn007
Thanks to all that replied to my thread.
The problem has been solved. Hazard light switch was not fully disengaged and there was also a bad bulb.
All is good again.
007
Old Sep 24, 2012 | 06:08 PM
AdamMeh's Avatar
AdamMeh
Glad you got it figured out.
Adam
To Signal Lights
