Uh oh..... :(
Old Sep 29, 2012 | 02:53 PM
Young Bill's Avatar
Young Bill
Default Uh oh..... :(
I dropped the TH400 pan and replaced the gasket.
Looked at a Haynes manual and it says in there that a dry fill of transmission fluid is 22 pints. I've put in 5 litres (which I think is 10.5 of your US pints) Have I overfilled?
Just been reading that there is oil in the torq convertor etc. I thought it was a dry fill as I removed the pan.
Any help is appreciated. If I have overfilled, whats the best method of getting it out?
Thanks people....
Old Sep 29, 2012 | 03:55 PM
oldalaskaman's Avatar
oldalaskaman
drop a corner of the pan over a bucket and let it drain
Old Sep 29, 2012 | 04:26 PM
Shark Racer's Avatar
Shark Racer
Actually, if you have long enough hose you should be able to suck it out through the dipstick tube.
Old Sep 29, 2012 | 04:37 PM
Young Bill's Avatar
Young Bill
That sucks
Reckon I'll try the pipe method first. Will it be like using a siphon? It'll taste bad I reckon
Old Sep 29, 2012 | 04:49 PM
oldalaskaman
better than gasoiline, worse than a chocolate malt, why dont you use a siphon pump
Old Sep 29, 2012 | 04:57 PM
Young Bill's Avatar
Young Bill
You have just given me an excellent idea Man from Alaska
I have a spare one of these used for training in my firefighter days
http://www.laerdal.com/gb/doc/123/V-...l-Suction-Unit
It will be perfect and I reckon I have a couple of spare reservoirs that I can keep the fluid in
Cheers
Old Sep 29, 2012 | 05:47 PM
oldalaskaman
Old Sep 29, 2012 | 08:50 PM
johnt365's Avatar
johnt365
What is your dip stick reading? That will answer your question. Draining the pan does not empty the converter, the converter has a seperate little plug to drain it.
Old Sep 29, 2012 | 08:58 PM
radiotexas's Avatar
radiotexas
aye lad, you put in 10.5 pints. How many pints drained out, 10.5?
regards, angus
Old Sep 29, 2012 | 10:06 PM
scottyp99's Avatar
scottyp99
Yeah, it holds 11 quarts, but when you drop the pan, only about half of it comes out. It sounds like you have around the right amount of fluid in there, maybe a little low. I'd fire it up, let it come up to temp, see what the dip stick says, and add fluid accordingly. What does the dipstick say now?
Keep the shiny side up!
Scott
Old Sep 30, 2012 | 02:41 AM
Young Bill's Avatar
Young Bill
When cold the stick is reading full, only 2 litres came out the pan approx. it was leaking though an wouldn't select a gear
Old Sep 30, 2012 | 02:51 AM
oldalaskaman
see what it reads when running, dont know bout 400's, but a 350 will blow excess out the vent tube
Old Sep 30, 2012 | 05:31 AM
Young Bill's Avatar
Young Bill
regards, angus
Hey Angus,
You an expat?
Thanks guys, couple of chores to do and then out to put in a wee shift. Let you know how I get on...
Old Sep 30, 2012 | 03:16 PM
Young Bill's Avatar
Young Bill
Default We update
Warmed up the Vette (took a wee run down the road for fuel ) and checked the oil in the trans, seems good and aint leaking not. nipped up the bolts and fingers crossed...
Thanks for the advise guys. Appreciated. You kinda feel alone waaaay over here
Old Oct 1, 2012 | 02:40 AM
aussiejohn's Avatar
aussiejohn
Default Drain plug
Willie,
Remember my advice about the drain plug? If you'd done that, you would not have needed to post this thread.
Regards from Down Under.
aussiejohn
Old Oct 1, 2012 | 03:13 AM
Young Bill's Avatar
Young Bill
thanks John
That's wee project for the future. Wonder why they never fitted one at the factory?
Old Oct 2, 2012 | 11:50 AM
Young Bill's Avatar
Young Bill
leaking
To Uh oh..... :(
Old Oct 2, 2012 | 11:56 AM
oldalaskaman
if its the pan gasket, it will swell up in a few days and stop leaking...if... you didnt over tighten the bolts, if not, a new gasket and an inch pound torque wrench, or a gentle snug up every couple days till it stops.
Old Oct 2, 2012 | 12:03 PM
Shark Racer
Did you check the pan rail surface for warpage? (on the pan)
Generally, they'll be bowed and cupped a bit and a couple hammer blows may be required to straighten them out.
Old Oct 2, 2012 | 12:10 PM
Young Bill's Avatar
Young Bill
I left it overnight and gave the bolts a wee turn. The leaking stopped and then started again. I'll try again. I think one of the threads on one of the bolts wasn't too clever. I'll keep my eye on it.
Gave the edges of the pan a wee clatter with a hammer and flat feather splitter chisel.
