Help*Needed (from down under)
Old Oct 3, 2012 | 07:48 PM
lou69's Avatar
lou69
Default Help*Needed (from down under)
HI there all
i own a 69 350/300 auto400, and recently replaced the engine harness prior to this the temp gauge used to go past 210 and then drop back down between 100 and 210 and stay there all day long.
after the loom change (and i know the temp sender is not in the loom) but now i start the car and the temp gauge just gets past 100.
i have taken 2 photos of the gauge reading and a temp gun (in Celsius)
i took the reading off the thermostat.
please take a look and pass any comments.
sorry about the links (photo bucket issues)
Regards
Lou
http://i963.photobucket.com/albums/a...ette/photo.jpg
http://i963.photobucket.com/albums/a...tte/photo1.jpg
Old Oct 3, 2012 | 10:37 PM
Aussie79's Avatar
Aussie79
I'll have a go at this seeing as no one "up over" wants to respond.
My guess is that the new loom has introduced less resistance or impedence in the circuit somewhere. The temp guage works by sending a 12V signal to the sensor and the sensor provides resistance based on temperature, you may need to add a resister in to the circuit to callibrate the guage, it will be hard to know what resistance would be required. My guess is that it is still working just not reading correctly, you could just live with it as long as the temperature rises so does the guage indicating an overheat problem. One simple test would be to pull the sensor and leave it connected, then submerge it is a pot of boiling water and see if the guage rises with the ignition on, if it does then its working fine but telling you porky's about the actual temp, this would also give you an indication of where 100c would be on the newly incorrectly callibrated guage.
Cheers, Dennis.
Old Oct 3, 2012 | 10:47 PM
lou69's Avatar
lou69
Thanks Aussie79
i was thinking that the new loom may have contributed to the lower reading.
do you think if i bought a new gauge it will give a better reading?
(i disconnected the green wire from the sender and grounded, and the gauge flicked from left to right)
cheers
Lou
Old Oct 4, 2012 | 07:15 AM
azza2u's Avatar
azza2u
Oddly my 68 with its original loom has the same issue with a new sender. I'm goung to be modifying the resistance at the sender to dial it in correctly.
Old Oct 4, 2012 | 03:27 PM
694speed350's Avatar
694speed350
Originally Posted by lou69
HI there all
Regards
Lou
dash gauge is reading slightly low. 78c=172f should be closer to the mark between 100&212 or just above it. gauge in car is in f.
Old Oct 5, 2012 | 09:51 AM
loup68's Avatar
loup68
Army
Lectric Limited sells correctly calibrated temperature senders. Lou.
Old Oct 5, 2012 | 06:25 PM
lou69's Avatar
lou69
Thanks for that
just visited the web site and sent a request for pricing
this could be what i need
cheers
lou69
Old Oct 5, 2012 | 07:42 PM
loup68's Avatar
loup68
Army
Glad to help, Lou. Us Lou's have to stick together! There aren"t that many of us! And then there are those Lew's, LOL. Lou Palfy.
Old Oct 5, 2012 | 11:52 PM
lou69's Avatar
lou69
And 2 lou's with a 68 and 69
Cheers mate
To Help*Needed (from down under)
