As we tear the car apart only to make it better. I have 4 tail lights thats it. And lic light. Anybody have drawings to tell me were the wires should go?
Stock would be two tail lights and two backup lights (inner pair). Do you have the assembly instruction manual (AIM)? The AIM shows how they mount and plug up to the rear harness. Are you removing these or installing them?
Order the AIM. You'll find it to be helpful for lots of things.
My wiring is a total mess, I reckon I need to replace the harness.
Looking at the Willcox site at the moment but can only see the front lamp harness?
Its real bad...
Inner lamp mess.
Would it be acceptable to make a waterproof junction box and completely make a custom harness and lamp holder that would do the job?
Its real bad...
Inner lamp mess.
What does acceptable mean?
I think I would just replace that, it does look bad.
If you can't find one, then take it out and simply duplicate it. I think all the connectors are available. Some soldering and heat shrinking and your good to go.
Thinking of chopping the harness up in the arch and fitting a waterproof junction box that will house all the new soldered connections. Found a UK supplier that does all the same colour cables. So reckon I'll go down that route... Just need to find lampholders.
