engine
Old Oct 6, 2012 | 02:00 PM
mk8035's Avatar
mk8035
Default engine
Have 350 in the car. What would i have to change if i dropped a 454 in her?
Old Oct 6, 2012 | 02:57 PM
Matt Gruber's Avatar
Matt Gruber
headers, pulleys, WP, FP brackets, air cleaner, maybe radiator, maybe springs due to 140# more weight.
Old Oct 6, 2012 | 03:08 PM
mk8035's Avatar
mk8035
Default Engine
Seems like no big deal
Old Oct 6, 2012 | 03:55 PM
jnb5101's Avatar
jnb5101
you'll need the externally balanced flex plate or flywheel. if it's a 4 speed you'll also need the 621 bellhousing to fit the 11" flywheel. i don't know(but i'd like to) if a 10 1/2 clutch will bolt to a 11 flywheel.
Old Oct 6, 2012 | 06:04 PM
dtamustang's Avatar
dtamustang
your underwear after your first ride
Old Oct 6, 2012 | 06:19 PM
Gordonm's Avatar
Gordonm
Rear tires more frequently!
On the flywheel some aftermarket flywheels are drilled and tapped for both 11 inch and 10.4 inch clutches.
Old Oct 6, 2012 | 06:43 PM
Tim H's Avatar
Tim H
well jump right into it for a weekend project and be driving Monday morning to work!
Old Oct 7, 2012 | 02:40 AM
oldalaskaman's Avatar
oldalaskaman
amen on this one
Old Oct 7, 2012 | 03:25 AM
3JsVette's Avatar
3JsVette
The frequency that you visit gas stations.
Old Oct 7, 2012 | 06:37 AM
fishslayer143's Avatar
fishslayer143
theres one more thing you will need that hasn t been mentioned.. a taller hood.
Old Oct 7, 2012 | 07:58 AM
KenSny's Avatar
KenSny
You will certainly need to get stiffer front springs and shocks otherwise the nose will be down. The weight difference is substantial.
Old Oct 7, 2012 | 12:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Seems like no big deal...
I suppose that would depend on your definition of "big deal." The swap is possible. It will be more work than you might think.
Old Oct 7, 2012 | 01:12 PM
Stingray-Jer's Avatar
Stingray-Jer
I'm not sure if you will need a larger radiator or not, but it is something to consider based upon the type of driving you will be doing. If not the radiator then maybe add and electric fan?
Old Oct 9, 2012 | 06:40 PM
iokepakai's Avatar
iokepakai
Swap in a 427ci small block & OD trans.Then tell em you just got smoked by a 350!! Wanna See...
Old Oct 9, 2012 | 08:30 PM
uxojerry's Avatar
uxojerry
For the price of a crate 454, you can get a lot more motor and horsepower. The following vendors have some nice choices.
1. Vortecpro performance.
2. ultrastreet.net
3. Nyes engines
Old Oct 10, 2012 | 10:43 AM
Doug Kraft's Avatar
Doug Kraft
Did the same 30 years ago. Get the right rad shroud, pulleys, headers and drop it in. I used the stock rad, springs and the bellhousing that came with the car, although I did put a new clutch on it. My motor had the balencer and flywheel already on it when I got it. When we were ready to set it in from the time I stopped the org 350 after driving over to my friends shop untill I started the big block it took alittle over 4 hours. Hardest part was driving back home thru town with the open headers. So if you ask me it really isn't a "big deal"
Old Oct 10, 2012 | 11:46 AM
joewill's Avatar
joewill
along with the taller hood, you will need to get it painted and fitted to match color and finish. good luck getting a shop to do that for you.. hood and paint probably add 1500-2000 to the project ... only if they can match it well..
engine itself, shroud, pulleys, belts, manifolds, exhaust, heavier front springs, heavier front sway bar, higher capacity radiator, wires, hoses, flywheel, damper, bellhousing..
while it is out.. clutch, restore engine compartment, rebuild tranny.. and more
at best a winter project and 10K, unless you pay someone, then 15K
To engine
Old Oct 10, 2012 | 12:20 PM
bashcraft's Avatar
bashcraft
Some people work faster than others.
I swapped in a 502 about 5 years ago. Used the SB radiator, springs, clutch fan and shroud. You'll need exhaust, accessory brackets, pulleys, belts, hoses and a case of beer.
Old Oct 10, 2012 | 12:32 PM
oldalaskaman
it mostly depends on your experience, but amen on the beer
Old Oct 10, 2012 | 01:26 PM
ezobens's Avatar
ezobens
I think the weight difference between a cast SBC and a cast BBC is only about 100-110 pounds?
Slap some aluminum heads, intake and headers on the BBC and you can probably get away with using the stock SBC springs IMO.
