B pillar trim
Old Oct 9, 2012 | 02:15 PM
1973's Avatar
1973
Default B pillar trim
HI
Does any one have any instructions for removing the "B" pillar trims on the inside of a 1973 T-top?
i took the screws out of the outside strip, and 1- from the seat belt shoulder trim- and 1- near the T top latch, are there any others? seems like it is still held near the rubber weather strip area, but i know if i pull that weather strip off i will destroy it, and was hoping to replace it at a later date when i re-paint the car-- perhaps too someone might have a used set of these weatherstrips to get me by- they are ABOUT a foot or so in length.
thank you!!!
Old Oct 9, 2012 | 02:39 PM
Alan 71's Avatar
Alan 71
Hi 73,
The lock pillar interior trim panel goes on first so the rear halo trim (1 each side) need to come off to release the lock pillar trim panel.
Have you tried that?
Regards,
Alan
It's the panel on the right in this picture.
You can see the screw to the right in this picture. There may be an addition screw in the dimple you see at the top/center of the trim panel.
Old Oct 9, 2012 | 02:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) will help. It shows how the trim was installed. It also shows the installation of the door ajar switches you were asking about.
Old Oct 9, 2012 | 02:59 PM
1973's Avatar
1973
actually the piece i am trying to remove is the one with the chrome trim screw still in it on your second picture, thank you!!!
does this upper trim piece also have to come off?
boy---
Old Oct 9, 2012 | 05:52 PM
Alan 71's Avatar
Alan 71
Hi 73,
Yes.
IF you want to take the lock pillar interior trim panel off.
No need to touch ANY weatherstrip that's in it's proper place.
The AIM is your friend.
Regards,
Alan
To B pillar trim
