Front Swaybilizer Bar Question.
Oct 11, 2012 | 07:59 PM
1968 - Small block.
The factory front ant-sway (stabilizer) bar was used on what years.
My instinct says 63-82 with small block only. But for all know they changed somewhere.
I put a heavier one on - and want to sell the factory one on Fleabay.
But I'd like to make sure I specify the correct years that would apply to a restoration project.
-W
Oct 11, 2012 | 08:57 PM
Are you speaking of the steering 'damper'? If so, I think that was '68 only.
Oct 11, 2012 | 10:36 PM
Quote:
Originally Posted by
7T1vette
No - I mean the sway bar.
Or better put
anti -sway bar.
Also known as a stabilizer bar.
-W
Oct 11, 2012 | 11:09 PM
Cruise-In VII Veteran
it's on ALL corvettes...
and the sway bar off a base small block ain't worth anything.
Oct 11, 2012 | 11:32 PM
RPOZ4Z
I know they all have one - I just wanted to know what years have
mine .
And I'm not going to throw it away....
You can bet that somewhere out there is a guy (with a small block) trying to
undo what I just did to my car.
-W
Oct 12, 2012 | 08:36 AM
Cruise-In II Veteran
RPOZ4Z
...the sway bar off a base small block ain't worth anything...
Except to anyone who might be looking for one.
Clams: if it's a standard small block front bar, it was used 68-74.
Oct 12, 2012 | 09:12 AM
Easy Mike
That's more like it!
I have all the original brackets and bolts and linkage to go with it.
As a follow up - are we sure that the same part wasn't used
before 1968?
-W
Oct 12, 2012 | 09:18 AM
Easy Mike
yes, but unless Clams bar is in MINT condition with no pitting on it, someone restoring a car that needs a new swaybar will buy a brand new swaybar..
they are only around $130.00 brand new.
Oct 12, 2012 | 09:21 AM
Clams Canino
...are we sure that the same part wasn't used before 1968?...
Get one of these and look it up.
Oct 12, 2012 | 09:27 AM
Easy Mike
You outta get a commission with all the books you try to sell here.
-W
Oct 12, 2012 | 09:28 AM
RPOZ4Z
UNLESS - someone is "restoring" a "survivor".......
-W
Oct 12, 2012 | 09:41 AM
Clams Canino
...You outta get a commission with all the books you try to sell here...
I don't sell books. I read books. When I read books, I learn things. I used that book to answer your question about your sway bar.
Oct 12, 2012 | 09:59 AM
OK - I listed it on fleabay.
Here's the link so we can all follow along and see if it moves.
http://www.ebay.com/itm/160900326077...witem=&vxp=mtr
-W
Note how I worked in the pic of all my good work....
Oct 12, 2012 | 10:02 AM
Listing looks good.
