Frame repair??
Old Oct 12, 2012 | 06:09 PM
bellaireroad's Avatar
bellaireroad
Default Frame repair??
Another question for the experts. This vette was rearended in the past, and the tail section/ rear bumper has been replaced. Also has had work done on the suspension as you can see. The frame has been sanded and repainted in the rear, but not all the way up- which seemed a little unusual, but maybe they just decided to clean it up a little when the rear suspension was rebuilt. Are those vertical frame weids normal, or has it had a patch job?
Old Oct 12, 2012 | 06:20 PM
SS164's Avatar
SS164
Vertical welds are not normal. Take a look at passengers side to see what that shows. Maybe rear section of rail was spliced. Need more pictures.
Old Oct 12, 2012 | 06:28 PM
bellaireroad
Thanks....that's kind of what I thought, seems a little suspicious. Unfortunately I don't have more pics
Old Oct 12, 2012 | 08:29 PM
merc49's Avatar
merc49
it looks like they cut a spot where the frame buckled and spliced in a new rear section.they should have used a frame machine to get the buckled piece back straight,but its faster to cut and weld a piece in than to spend the hours necessary to fix it right.since that spot is right over the spring and crossmember i would weld in a 1/4 in. plate on each side over the welded area at least 2 inches past each weld,basically covering the seam they left.you really only need it on the outside and inside to be effective not the top and bottom.im just a welder and that is how i would fix it and when i was done, if it were my car i would drive it anywhere without any worries.
Old Oct 12, 2012 | 09:21 PM
7T1vette's Avatar
7T1vette
I'm thinking that 1-1/2" wide piece at the center of that member IS a piece that overlaps the initial weld point. If that piece is made of good material and the welds were done properly, it's probably as strong as the original frame. But, you will have to investigate to see what you actually have there.
Old Oct 13, 2012 | 11:02 PM
bellaireroad
I think you are right, I was wondering why two welds were there
To Frame repair??
