Dumb Headlight Switch Question
Old Oct 16, 2012 | 06:45 PM
corvette_maniac's Avatar
corvette_maniac
Default Dumb Headlight Switch Question
What is the purpose of the spring in that switch. Does it serve as the resistor for varying the brightness of the gauge lamps?
Mine fell out and the switch is brittle. Still functions so I'm debating on replacing it.
Old Oct 16, 2012 | 06:59 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
It does and you should.
Old Oct 16, 2012 | 07:56 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
When switches start to fall apart you could end up with "dashboard flambe."
Old Oct 16, 2012 | 08:42 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Replace the switch ASAP
Old Oct 17, 2012 | 11:33 AM
TWINRAY's Avatar
TWINRAY
Avoid the cheaper switch that you'll find in the likes of Autozone. It is cheaper because it doesn't have the vacumn hose connection.
To Dumb Headlight Switch Question
