CD Player Install Help
Old Oct 18, 2012 | 05:08 PM
GeosVette's Avatar
GeosVette
Default CD Player Install Help
To those that have upgraded to a CD player. Can you describe what modifications you did inorder to accomadate a nice uptodate radio / head unit? I have a 1978.
Old Oct 18, 2012 | 05:12 PM
MrJlr's Avatar
MrJlr
New instrument bezel from Willcox....
Old Oct 18, 2012 | 05:46 PM
Shark Racer's Avatar
Shark Racer
The pre-cut bezels have a $100 surcharge for 20 minutes of work.
Got the bezel from wilcox. Jigsaw or dremel on low speed and it's eeeeasy. Just measure a couple times.
If you're doing a later model(77-82 I believe), they have adapters to attach connect to the stock harness. You'll need to add your own memory wire (always-hot 12V).
I did, however, get my new bezel from Willcox.
Old Oct 18, 2012 | 05:59 PM
GeosVette's Avatar
GeosVette
Looks GREAT that's exactly what I want to do. I just added some pioneer 3way 4x6 speakers now I'm trying to figure out how to remove the instrument cluster panel. It's stuck in there good. I took out the old radio already. What's holding the radio in place? Is there something behind the radio or some sort of bracket you got to secure the radio in the new opening?
The plan is to take out the console and use a dremel with a cutting disk. I just cant figure out how to remove the console. I took out the two top screws then the two side screws. There there were a couple of screws / pins attached to the center console. Also the old radio is out. Any advice on taking out that console?
I got lucky the previous owner prewired the radio with the adapter for a Pioneer cassette player. I just need to figure out the pin layout.
Old Oct 18, 2012 | 08:38 PM
Tim H's Avatar
Tim H
On a 76, you keep cutting and grinding until it fits or you can cover it up with a plastic trim piece!
Old Oct 18, 2012 | 11:41 PM
Shark Racer
Probably wise to use the trim piece anyways as the volume and tune ***** sat into a recess that will be very visible when finished.
(on the 77-82 cars this is not an issue)
Old Oct 19, 2012 | 05:51 AM
iokepakai's Avatar
iokepakai
This is on my 76 with the bezel trim piece that covers the cutout.Makes for a cleaner install.What year is your car?
[IMG][/IMG]
Old Oct 19, 2012 | 08:49 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
When I was doing it I thought for earlier years the aftermarket bezel was way more than $100.
I just opted to modify my original
Buy the $7 trim piece.(i can get you the number if you need if your bezel is the early curved type.)
use a dremel to cut out the square...
Install.
Old Oct 19, 2012 | 09:14 AM
GeosVette's Avatar
GeosVette
Trim piece is a great idea. If I can figure out how to take out the Bezel I'll take that route. I may even just order a new bezel for $45 and cut that out. If I have the trim piece to cover my mess all should be good. I just need to get the center piece out. I was planning on trying to recondition my bezel first. Was going to lightly sand clean and spray see how that comes out before ordering a new bezel and trimming.
Install.
Old Oct 19, 2012 | 09:26 AM
PUNISHER VETTE
My bad...it was $11 not $7.
http://www.hifisoundconnection.com/S...id/0/SFV/30046
way cheaper than buying a whole new bezel if you're not afraid to cut your stock one. It's marked for where you need to cut for a DIN radio.
necessary for any 68-76 cars with the curved bezels.
Old Oct 19, 2012 | 11:47 AM
Shark Racer
$100 premium (I wrote surcharge), not $100 for the piece.
To CD Player Install Help
