Headers and alternator bracket
Old Oct 20, 2012 | 07:45 PM
rafalc's Avatar
rafalc
Default Headers and alternator bracket
So Im going with headers and need a good alternator bracket. Ive read here on the forum that some of the brackets the vendors got are weak and that a forum member was making his own, which ended up being of good quality.
I need your opinions. I was considering this one:
http://www.summitracing.com/parts/SME-2001/?rtype=10
Yay? Nay?
Will the alt line up with the belt exactly as it was stock?
Old Oct 20, 2012 | 08:16 PM
toddalin's Avatar
toddalin
You could use a Header Power Bracket. Then you would have front/rear adjustment to be sure the belt lines up.
http://headerbracket.com/
Old Oct 20, 2012 | 09:21 PM
oldalaskaman's Avatar
oldalaskaman
Alan Grove
Old Oct 21, 2012 | 12:52 PM
C3 Stroker's Avatar
C3 Stroker
I've found that the stock 1971 bracket and adjustment arm works the best......perfect fit, no issues.
Old Oct 21, 2012 | 06:29 PM
rafalc's Avatar
rafalc
Hey....a 1971 bracket is identical to my 1970 stock bracket (according to some schematic diagrams I found). If thats the case then the bracket has a blt going though the alternator and into the stock manifold for stability.
With headers...that bolt has nowhere to go. Do you have a picture from the other side of the engine bay showing the alternator setup?
Old Oct 21, 2012 | 10:05 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I've been using the one you show in your Summit link. No problems with belt alignment here.
Terry
Old Oct 21, 2012 | 10:14 PM
Jasonb86's Avatar
Jasonb86
I agree with raflc. Use a later model (I believe it's 72 and up) and you're good to go. They're on eBay all the time for $30-$50. Here's mine:
Old Oct 21, 2012 | 10:33 PM
rafalc's Avatar
rafalc
Thanks!
Will the stock length belt still be good?
Old Oct 22, 2012 | 02:29 PM
C3 Stroker's Avatar
C3 Stroker
Here's a link to the bracket I have.....it is GM part #3951337.....350 alternator bracket.
https://www.paragoncorvette.com/p-35...g-bracket.aspx
Old Oct 22, 2012 | 03:05 PM
briankeery's Avatar
briankeery
Originally Posted by oldalaskaman
Alan Grove
100%
Old Oct 22, 2012 | 03:15 PM
Jasonb86's Avatar
Jasonb86
I was able to use the same alternator belt after changing to the '72 alternator bracket.
To Headers and alternator bracket
