they're junk if:
1) when you jack one tire off the ground and move the wheel back and forth (like steering) and one or more of the joints move
2) if, when you move the steering wheel, not all of the joints actually move in unison.
in any case, it's hard to test them without substantial leverage, and it really helps to have a helper.
other tests - how does the car drive? do you have to herd it down the road? is the steering vague? are there easy and hard places when you turn the wheel?
From the Chevrolet Chassis Service Manual.
"Replacement of tie rod ends should be made when excessive up and down motion is evident or if any lost motion or end play at ball end of stud exists."
I seem to remember the GM mechanics pushing up and pulling down on the tie rod ends. Any detectable up and down motion was cause for replacing the tie rod end(s).
Jim
That's never worked for me
I did forget one bit - make sure the wheels are at ride height when you check ball joints (put your jack under the ball joint) - because different angles have different amounts of wear
I am cleaning up the steering components and was just wondering about the tie rod ends. Car is off the ground with wheels off. Tie rods are already off the car.
I think Ill just get new ones as they're not too expensive.
That would be the safest bet - for myself, my rule of thumb is replace the joint if the boot is torn (unless I've torn it from having to remove it a few times).
also consider poly boots - they last better than rubber.
IMO, tie rods aren't that expensive and if the boots are gone, I'd say it wouldn't hurt to replace them - and yes, get the poly boots like said above. I'd stay away from cheap "kit" parts and get (even though they aren't as good as they use to be) Moog or maybe Raybestos parts.
THIS.
TR's for our car are very cheap, even "name brand" ones.
If you are going to take apart anyways why not just install a new one and put some good grease in it.
Since you already have them off, just pull up and push down on the threaded part. You should have no up and down movement at all. Rotation in the socket is OK. They are designed to rotate.
Yep, thanks guys. Im ordering new ones. Also getting a new adjusting sleeves as I know from previous experiences how much of a b@tch it is to get the tie rod ends out of them (even with heat).
