First vette
Old Oct 22, 2012 | 07:58 PM
Billynjuls's Avatar
Billynjuls
Default First vette
i just purchased my first vette to restore. The guy before me stripped it all the way down to the bare fiberglass. What should I put on it so I don't keep getting fibers in my skin? Also, I'm pretty mechanically inclined so what would be the best material out there to help in the restoration. I already have the AIM and the corvette restoration guide, chassis service manual. Anything else I should get? Thanks.
Billy
Old Oct 23, 2012 | 01:14 AM
oldalaskaman's Avatar
oldalaskaman
if you posted pictures you would get better advice
Old Oct 23, 2012 | 10:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Billynjuls
...What should I put on it so I don't keep getting fibers in my skin?...
You should not be getting fiberglass fibers on your skin. Was the PO in the process of doing body work on the car?
Put a coat or two of good quality primer on it then see what you have.
Old Oct 23, 2012 | 10:19 AM
Billynjuls's Avatar
Billynjuls
Thanks. I believe he was just stripping the paint off and that's all he got to. Any suggestions on what brand of primer. I'm not concentrating much on the body work now as my plan is to get the body pulled and then work on the chassis. It only has 30,000 original miles so it's in good shape body wise. The only problem I have found so far is some pitting on the driver and passenger birdcage pillars. I plan to have a shop fix those as I'm not much of a welder. Thanks.
Billy
Old Oct 24, 2012 | 10:03 AM
straitjacket's Avatar
straitjacket
eastwood has a high build primer suitable for gelcoat for fiberglass. it is made by USC.. . it comes by the quart in a blue can. this is what i used when we repainted mine. i found it on ebay.
billy
Old Oct 25, 2012 | 08:23 PM
Billynjuls's Avatar
Billynjuls
billy
Thank you. That is what I was needing to know.
Billy
Old Oct 25, 2012 | 09:17 PM
junkman123's Avatar
junkman123
i use slick sand on all raw glass im working on.
http://www.evercoat.com/productdetail.aspx?pid=28
To First vette
