Tilt Steering Wheel in C3?
Any insights would be greatly appreciated. Thanks in advance.
pretty easy , depending on your skillset
here, the venders , fleabay
btw, C5/6 seats are a good upgrade for these
hope this helps
81-82's offered an optional power drivers seat. The floor was deeper in those cars, to accommodate the power seat's motor, but even in the seat's lowest position, the headroom available was about the same as earlier cars.
Other than removing foam from the lower cushion (and there isn't much there to start with), I don't think there is much you can do to lower the seat.
Your best bet is to keep looking, until you find a car with the tilt & tele column. If you do locate a car you like, that doesn't have the tilt & tele column, they can be retrofitted. All 69-75 columns are the same, and are a direct bolt in. Unfortunately, the 69-75 T&T columns are getting harder to find, and have gotten more expensive too. Your probably looking at around $1,000+, for a rebuilt one these days.
The 76 column needs a different steering wheel hub, and other upper parts to work. The parts are available, but it's probably not worth the effort.
77 is a one year only column, and for various reasons, should be avoided.
The 78-82 columns are a little shorter, and have the high/low beam switch, on the column (earlier cars use a floor mounted foot button). People have made them work, but they don't go in quite as nicely as a 69-75 column.
There are also custom columns available from companies such as Flaming River.
http://jimshea.corvettefaq.com/?p=894
Jim
I guess my seats are SHOT because Im 6'2" and still have plenty of head room.
Miles
seems almost every car I like, doesn't have T & T and for me, it's a must have option.
I've considered doing a retrofit on just the right car, but why do it if you don't have to? I'm now patiently waiting for the right car to come along.
mardyn
Of course, going topless would give you max headroom.
I'll be here all week.T&T is nice. Have it in my '78.
Back in the early C3 years, T&T columns were only 50% of the volume. That is why the "round head" T&T columns are fairly expensive.
Jim
I am a solid 6'4" and needed to do this to keep from my forehead being hit by the bugs from it sticking up above the windshield. I have a convert which I think should give you a little extra room compared to t-tops.
