Dash lights?
Old Oct 25, 2012 | 06:26 PM
tyancey00's Avatar
tyancey00
Default Dash lights?
This winter I would like to fix the dash so I can see the speedo, tach,and everything in the middle. Anyone have any info on some LEDs or something like that? I don't want to drop a ton of bucks, jus make it so I can see ...
Old Oct 26, 2012 | 05:47 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
ripping the dash apart is no picnic,
1 reason people add LED's is so they never have to back into the dash again,
determine your Dash bulb# then its easy to shop around for different LED's.
If your going for cheap just replace the bulbs, new LED set will cost about $25 -50
depending upon LED selection.
here is a good LED supplier: www.SuperBrightLEDs.com
Old Oct 26, 2012 | 07:12 PM
PhotoVette1's Avatar
PhotoVette1
I'm doing these--seems ideal. You can adjust color and brightness any time.
Old Oct 26, 2012 | 07:38 PM
mn_leaf_fan's Avatar
mn_leaf_fan
Me too.
Old Oct 27, 2012 | 12:25 AM
7T1vette's Avatar
7T1vette
Pull the cluster and pull out the driver's dash pad...then change the bulbs and make sure the grounds are connected. If you do only that, along with having a decent condition headlight switch, you will have no problem. If the headlight switch is "toast", throwing $$$ at LED's won't help you either.
Old Oct 27, 2012 | 08:15 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Thats pretty cool. I would love to see a video of this installed when you are done. At at the most a pictured write up of the install.
Old Oct 27, 2012 | 09:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7T1vette
...If the headlight switch is "toast", throwing $$$ at LED's won't help you either...
Have you checked the IP fuse? Blown fuse = no lights.
Old Oct 27, 2012 | 11:32 AM
MrJlr's Avatar
MrJlr
http://forums.corvetteforum.com/c3-g...king-pics.html
Old Oct 27, 2012 | 01:26 PM
PhotoVette1
One reason white LEDs look so blue on our gauges is because the gauge frame is painted blue.
This was done to make the warm orange light coming from the incendescent bulbs look white even when dimmed.
LED white lights tend to be blue-ish instead of warm so:
To get your LED lit dash to look more white, simply paint the gauge frame back orange where it was blue. Chevy Orange engine paint is perfect.
To Dash lights?
