HEADLIGHTS WIGGLE on a 74
Old Nov 1, 2012 | 11:25 AM
scf100's Avatar
scf100
Default HEADLIGHTS WIGGLE on a 74
when up they seem to wiggle/jiggle slighty.....
maybe not fully locked open or??????
Old Nov 1, 2012 | 12:00 PM
CQRT's Avatar
CQRT
When they're on/up . . grab with your hand and pull up gently - - -or push down . . . do they move at all?
Old Nov 1, 2012 | 08:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Possibly worn bushing in the side.. Worn linkage bushings, Actuator tension not adjusted properly.. Support broken on the end, corrosion on the rear of the supports allowing it to move.. there lots of things that can cause this.
In this video you'll see me finding a worn bushing in the actuator clevis.. it cluncked.. We are gearing up on doing a video about putting the housing together soon... We have all the part removed from two housings and are going to video tape the rebuilding process.
You just need to find out what is loose.. Possibly re-adjust the stops and then see what you get. You may have multiple issues causing the wobble.
Old Nov 5, 2012 | 06:32 PM
scf100's Avatar
scf100
yes,when up position you can move them slightly......adjust the stop on them?
Old Nov 6, 2012 | 10:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by scf100
...adjust the stop on them?...
I'd try that first.
To HEADLIGHTS WIGGLE on a 74
