Thanks, Billla!
Old Nov 2, 2012 | 01:40 AM
scottyp99's Avatar
scottyp99
Default Thanks, Billla!
I just received the cam and lifters that Billla sent me, free of charge. He didn't even charge me postage, said to consider it a gift. I just want to give him a shout-out and acknowledge his generosity in public, so to speak. Thanks, Billl, you're a real class act! I'll make sure and pay it forward when I get the chance. Gotta keep the Karma going around, right?
Keep the shiny side up!
Scott
Old Nov 2, 2012 | 06:59 AM
Jedi926's Avatar
Jedi926
Smooth Billa.
Old Nov 2, 2012 | 09:09 AM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
He and several others have helped this rookie out a lot! It's great that these guys offer up their time and experience. They make this forum an outstanding resource
Old Nov 2, 2012 | 10:01 AM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
This has always been a helpful forum and typically welcoming of newcomers and novices unlike many other car forums.
Rob
Old Nov 2, 2012 | 11:34 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Good post! Encouraging for certain!
Old Nov 2, 2012 | 06:19 PM
billcarson's Avatar
billcarson
"i don't know whats gotten into those two".
Old Nov 2, 2012 | 07:14 PM
76Vett's Avatar
76Vett
Helping others never goes out of style - Good to see forum members helping each other -
Old Nov 2, 2012 | 07:20 PM
AdamMeh's Avatar
AdamMeh
Classy move Billa! Enjoy the cam Scotty... what cam is it? Come on man... we need some specs!
Old Nov 2, 2012 | 08:16 PM
mds3013's Avatar
mds3013
Bill is a good guy. Have fun with the CAM. mike...
Old Nov 2, 2012 | 10:38 PM
scottyp99's Avatar
scottyp99
It's a .420/.442, 204/214, 112 LSA cam, I'll be using a different cam, but I will be using the lifters in my engine. I'll save the cam and someday one of my buddies will say something like "I'm thinking about putting a little bit bigger cam in my small block.". And I'll say "I have a cam for you, free of charge, but you'll have to buy some lifters.". Here is the cam I will be using:
http://www.summitracing.com/parts/su...make/chevrolet
Don't try to talk me out of it, It's already bought and paid for.
Scott
Old Nov 2, 2012 | 10:55 PM
Muddywaters's Avatar
Muddywaters
Thead does not surprise me in the least... some great people around here!!
Nearly lost me drink! Muddy
Old Nov 3, 2012 | 03:15 AM
Tim H's Avatar
Tim H
Yeaaaaa!!!! 110 lobe separation!:cool :
But it says "lopy rough idle with a 216@50? Maybe in a 267 CI, but crazier things have happened!
Keep you eggs sunny side up but your bacon greasy side down!!!
Old Nov 3, 2012 | 03:40 AM
Shark Racer's Avatar
Shark Racer
I'm running a Crane Energizer with the same dur/LSA as that cam, and it's not too lopey at all. Certainly more than an L48 cam, but I wouldn't call it cammy.
Of course, the Summit COULD have way different timing events, but I wouldn't be surprised if it's just the Crane Cam with the house branding...
Old Nov 3, 2012 | 08:25 AM
scottyp99's Avatar
scottyp99
I'm pretty sure that's exactly what it is.
Scott
Old Nov 3, 2012 | 09:43 AM
wilcar's Avatar
wilcar
That cam will have a nice throaty idle in a 350 but not a rough idle. It will have lots of low and mid range punch.. I ran a similar cam, and isky 264 Mega cam, 214-214, .450 lift on a 108 LSA, in my 76 L82 and was a great cam(had much better low and mid range than the L82 cam) and is easy on the valve train and you can use your stock springs too. Good luck.
Old Nov 3, 2012 | 11:48 AM
REELAV8R's Avatar
REELAV8R
I like that cam choice. Almost exactly what I am looking at. Since your using the same heads, gasket and stock pistons, I'll be curious to see how it works for you. You may beat me to the end product.
You figuring to get what, about 325-350 HP out of that combo? Will you be doing anything with the exhaust system?
Old Nov 3, 2012 | 11:56 AM
Street Rat's Avatar
Street Rat
That Billa guy must be a class act. Like so many other fellas that I've met through the CF. I really enjoy reading his technical responses and posts.
To Thanks, Billla!
Old Nov 3, 2012 | 12:10 PM
scottyp99's Avatar
scottyp99
I'm glad to hear that, I don't have much experience picking cams for small engines (my last hotrod was a '73 roadrunner with a 440 in it, I think I ran a 292/.501 Isky cam in it with a 3.55 diff ratio. Not sure what the stall was, it was a long time ago, and back then the hot low-buck set-up was to get a converter out of a slant six car from the junkyard. It ran really well, I could stomp the gas pedal from a standing start and pretty much just burn the 255/60/15 tires until I decided to let off, but that cam in a 350 would be a completely different animal!) so I'm a little concerned about overcamming the engine. I've done my homework, listened to other's advice, and paid my money, hopefully I will be happy with my choice. What you are telling me is exactly what I want, so it's looking good! I'll be using aftermarket aluminum heads with new valve springs, so I'm not really worried about that too much.
Scott
Old Nov 3, 2012 | 12:17 PM
Shark Racer
Just make sure you have good static CR or you will give up a fair amount of low end. I went from the L-48 cam to that and it's definitely weaker below 2500. Much more powerful beyond that though.
Old Nov 3, 2012 | 12:37 PM
scottyp99's Avatar
scottyp99
That link is busted, I think, can you re-post it?
Yeah, I'm looking for about 325-350 HP, and hoping to break 250 on a chassis dyno.
I have a Corvette Central exhaust system on it now, it is a set of ceramic coated block-hugger headers, 2 1/2" aluminized exhaust with an H-pipe, and stainless steel Magnaflow mufflers. I like how it sounds, but am contemplating changing to long tube headers at some point. Here are the headers I'm looking at:
http://www.summitracing.com/parts/su...model/corvette
Awww, man!!!! They jacked up the price again! They were less than a hundred bucks not that long ago! Wow, I'm really starting to sound like a grouchy old man, huh? Get off my lawn, you damn kids! *shakes fist*
OK, I'm pretty sure I'm going to take some flak for this, but I am seriously considering using these heads:
http://www.speedwaymotors.com/Flo-Te...lug,25118.html
Car Craft used a set of them in a test of seven different aftermarket heads, against stock heads, and they did pretty well for how much they cost. Here's a link to the article if you're interested:
http://www.carcraft.com/techarticles...t/viewall.html
Scott
