[LS Swap] Air Intake Help
Old Nov 6, 2012 | 09:05 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Default [LS Swap] Air Intake Help
Sorry, I hate bugging you guys with so many questions but....
I need an intake setup and am trying my best to avoid the common 90degree type.
I've seen a few that have a dual intake or the one in a C2 with a wide one.
Just wondering how to they go about not having the MAF sensor and isn't it supposed to be something like 4" away from the throttle body?
Anyone have any input or suggestions that might help?
Old Nov 6, 2012 | 09:30 PM
Corey_68's Avatar
Corey_68
If it doesn't have a MAF they had it tuned for speed density. There are advantages for both, speed density is ideal for F.I. Setups.
Old Nov 6, 2012 | 10:25 PM
oldalaskaman's Avatar
oldalaskaman
excellent
Old Nov 7, 2012 | 03:18 PM
PUNISHER VETTE
ugh. I guess I can try hooking the MAF up right to the throttle body then seeing if I have enough room for a T intake...
stupid setup having a 4" throttle body and a 3" MAF...
Old Nov 7, 2012 | 04:18 PM
Corey_68's Avatar
Corey_68
FYI car #1, #3, and #4 are running MAF sensors, just not the large LS1/LS2 style MAF.
Old Nov 7, 2012 | 04:22 PM
PUNISHER VETTE
Is it an upgrade I could switch to the LS3+ style MAF?
Or not possible?
I saw online that the MAF is tuned for each car so I guess if I get a new MAF it'll need turning?
Old Nov 7, 2012 | 05:58 PM
PUNISHER VETTE
Well. I just took some measurements and basically i'm stuck with the 90degree single cone setup unless I do a SpeedDensity tune.
I'm not saying that is out of the question as from what I read they're good...although I have never tuned before so I'll have to do a lot of research to see if I could do it myself or not. Maybe in the future.
Old Nov 7, 2012 | 06:36 PM
PUNISHER VETTE
Just ordered the parts to build this...so at least if i'm doing a 90 elbow it'll be a BIG elbow.... except I ordered a red filter.
My only question now is the small 1" round IAT sensor that was in the stock intake that I assume I need to install in the new one? Just curious if there is a special place it needs to be.
Old Nov 8, 2012 | 04:08 PM
User-C3's Avatar
User-C3
for the IAT sensor This is what I made so it was able to be screwed in. Just put it in a location that wasnt right in your face. Doesnt matter where it is on the intake tube.
I used a brass fitting, opened up the inside of it to fit the sensor, and then used 2 ton epoxy to seal it in. being very careful not to get any on the actual sensor tip.
Old Nov 8, 2012 | 06:33 PM
Shark Racer's Avatar
Shark Racer
Not sure if that's a great bend for that MAF. You need a certain amount of straight before and after the MAF and that looks like it'll be turbulent air on both sides.
The reason MAF and MAP are used in unison has to do with the accuracy of the sensors. MAFs work really well at high speed and are a true measure of air-flow. MAPs work really well at low air speed but are based on equations (PV=nRT). If you have a correct MAF curve(transfer function) in a MAF system, you'll never have to re-tune your MAF.
When the engine is modified, then the vacuum signal the MAP sees has a completely different meaning thus the lookup function (VE (volumetric efficiency) table) needs to be modified to accurately reflect the combination.
FWIW.
FYI
http://www.chevroletperformance.com/...44807E-ROD.pdf
Originally Posted by GM E-Rod manual
Ensure the MAF Sensor is mounted in the middle of a minimum 6 inch length of 4 inch diameter tube, and is a minimum of 10 inches from the throttle body.
Old Nov 9, 2012 | 07:15 AM
PUNISHER VETTE
FWIW.
FYI
What would be symptoms of turbulent air at either? So I know if it needs fixed or the MAF tuned...
I havent looked yet but is the stock trans am IAT removable and reusable?
Old Nov 9, 2012 | 11:43 AM
Shark Racer
Typically IATs on the LS cars are integrated with the MAF.
Turbulent MAFs would have inconsistent readings, especially at lower speeds, and not run particularly well because they're getting incorrect readings. If you're running a MAP as well it will probably mask this behavior.
Old Mar 25, 2013 | 09:30 PM
donnie1956's Avatar
donnie1956
Old thread but anyone got a new way to get fresh air. I am doing speed density with a Holley ECU.
Old Mar 26, 2013 | 11:41 AM
mark6669's Avatar
mark6669
I used a Street and Performance combo MAF & Air Filter assembly works great.
Mark
Old Mar 26, 2013 | 08:57 PM
Learning_Curve's Avatar
Learning_Curve
Not an LS, but same idea. I rigged this up today using bits of a Camaro air induction kit. I'm going to need to get a tune before startup anyway, so I'm going to have them convert it to run on Speed Density. I'll keep the MAF connector intact in case I ever decide to change.
I tried to mount the filter directly on the throttle body but it would not clear the thermastat housing. Since the cold air kit was just sitting around, I cut the mounting plate from the piece that connects the intake tube to the filter to give me my added length. It also gave me a place to mount the IAT sensor. You can see what it looked like before in this pic.
Now to get cold air I would like to put a tray below the filter and run it to the top of the radiator. I would like extend the sides of the tray up to seal to the hood, and do this for good measure.
1980 hood modified to create a scoop.
To [LS Swap] Air Intake Help
