What is going on?
Old Oct 16, 2019 | 02:30 PM
ronarndt's Avatar
ronarndt
Glad the radiator was un-damaged. Looks like UPS gave it "special handling". You will like the improved cooling capacity. The PO of my 68 convert with NOM 454 installed a four row champion aluminum radiator and added an electric fan. He kept the stock fan and shroud. I removed the stock fan to see if it was actually needed and found it was not, so I also removed the bulky metal shroud. This really gave a lot more room- enough to add a strut brace from side to side. Hope your new cooling modification works well for you.
