What is going on?
Old Nov 8, 2012 | 11:24 AM
Young Bill's Avatar
Young Bill
Default What is going on?
You may have spotted my radiator removal thread. Thought I would add a fresh thread. Sourced a replacement mount luckily in the UK and it looks good. Slots in the space no problem but the radiator doesn't sit in very well
Mount
Bottom passenger side, note the gap
Another view
Driver side sits in fine
Is my radiator the wrong one?
Anyone got pictures of what the radiator should look like fitted? Will I need to break off and reweld the bottom bracket? Or am I just being a fud?
Old Nov 8, 2012 | 11:30 AM
oldalaskaman's Avatar
oldalaskaman
you need the rubber cushions, and then you need to make slight...adjustments
Old Nov 8, 2012 | 11:40 AM
Young Bill's Avatar
Young Bill
Cheers amigo,
I'll need to order up the cushions, I have 2 $37 to get them delivered to the UK
You recken if I cut them off and reweld them to fit that they should be fine?
Old Nov 8, 2012 | 11:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You possibly have an incorrrect radiator support or an incorrect radiator.
If memory serves, you were intending to order the assembly instruction manual (AIM) for your model year. Has it arrived? The AIM shows the correct radiator support for your model year, the correct radiator, the correct mounting brackets, and lists the original GM part numbers for everything.
Old Nov 8, 2012 | 12:05 PM
Young Bill's Avatar
Young Bill
Yes Mike,
It looks the same on the AIM although I don't have any part numbers on the radiator. What I will do is measure the radiator and put the dimensions on here that maybe someone will be able to compare.
Appreciated as always
Old Nov 8, 2012 | 12:06 PM
oldalaskaman
those brackets bend easily and with some 'gentle' adjusting will probably work fine, the guys that order the aftermarket ...non-dewitt...radiators go thru the same issue
Old Nov 8, 2012 | 12:17 PM
Young Bill's Avatar
Young Bill
Its and aftermarket I think. If it doesn't adjust I'm taking the block out and getting VW donor engine and going air cooled :/
Old Nov 8, 2012 | 12:27 PM
oldalaskaman
I hear a corvair 6 is a direct bolt in swap , and it would still be 'all' chevy
http://www.google.com/imgres?hl=en&s...9,r:4,s:0,i:87
Old Nov 8, 2012 | 12:38 PM
Young Bill's Avatar
Young Bill
Now a wee horizontally opposed set up might be just the job
Turn the car into a wee flying machine.... See what I did there?
Old Nov 8, 2012 | 12:42 PM
StingrayLust's Avatar
StingrayLust
Default aftermarket radiator
Definitely an aftermarket radiator. Yes you're missing the rubber bushings on the bottoms and completely missing the top 2 brackets that mimic what the bottom ones do. It's hard to tell from your pictures if the bottom outlet on the radiator is hitting the bracket. What year is your car again and SB or BB? Must be an automatic because of the built-in tranny cooler in/out line in the radiator.
Are you sure you have the right bracket you sourced? There were 3 different brackets from some years for different radiators. For example, my '71 had a different bracket for the SB 18", SB 26", and BB 27" radiators. You definitely don't have the SB 18" bracket because there would be some flat metal covering the inner left and right sides.
Old Nov 8, 2012 | 12:54 PM
Young Bill's Avatar
Young Bill
Its a 75 ( but reckon it has a 74 front clip) Standard L48. The main issue I had was that the old one was a bit ragged and knocked about with a hammer. The bottom pipe was also tight against the sway bar. (pics on here of the removal) The seller said that this was a 73 to early 76.
I have the drivers side upper bracket but will need to get a hold of everything else including the shroud and all the fittings.
Old Nov 8, 2012 | 01:33 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Young Bill
...Its a 75 ( but reckon it has a 74 front clip)...
Does it have a 74 front clip? Radiator supports could be different between those two model years.
Old Nov 8, 2012 | 01:39 PM
Young Bill's Avatar
Young Bill
Looks like a 74 to me could it be older? That could be the issue if it was pre 74...
Old Nov 8, 2012 | 01:50 PM
Easy Mike's Avatar
Easy Mike
Yep. 73 or 74.
Old Nov 8, 2012 | 01:52 PM
Young Bill's Avatar
Young Bill
Yep. 73 or 74.
73 to early 76 is the same one so can't be that Hammers coming out
Old Nov 8, 2012 | 03:16 PM
dembo's Avatar
dembo
Not exactly, from 75 on the middle section of the bumper kicked up , 73-74 ran in two straight lines towards the middle like yours.
Nick
PS love the wee's in your posts always makes me laugh. Have some good memories playing online in a Scotch gaming team
Old Nov 8, 2012 | 03:20 PM
Young Bill's Avatar
Young Bill
Nick
I get it that the front is a wee bit flatter in the middle but I take it that the radiator mounts will still be the same?
I'm fair scunnered with it
To What is going on?
Old Nov 8, 2012 | 03:47 PM
Easy Mike's Avatar
Easy Mike
...I take it that the radiator mounts will still be the same?...
Possibly not. I do not have a 73 AIM (yet), but I have a 74 and a 75. I will not be able to check part numbers until later this evening.
AIMs say the radiator support is the same #399176 for all 74s and 75s. The correct support has studs on the lower brackets for mounting the fan shroud. Four different radiators are listed for the 74s depending on transmissions and factory air. #3030684 is correct for 74s with automatic tranmissions and correct for 75s. Radiator #3030199 for 74 is for AT and AC cars. It is also the service replacement radiator for 73-76 cars. These are coded MC.
The correct fan shroud for small blocks is #342287.
Old Nov 9, 2012 | 04:24 AM
Young Bill's Avatar
Young Bill
cheers Mike, mine is an auto with air (although disconnected) planning to spend a few hours on it at the weekend test fitting.
Old Nov 9, 2012 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Check your radiator for a small metal tab near one of the tanks with MC stamped on it.
