i have a 69 350 and the gauge has always read high when on the highway its sit's all the way over the right,
and when i am stopped at lights it sit's in the middle.
when the engine is off i can see oil in the line but it's patchy.
i loosened the brass coupling at the rear of the gauge and started the car when the oil started coming out i tightened it up,
this didn't help.
do i need a new gauge?
see attached photos
cheers
lou
First: The oil line will not be fully charged with oil unless you fill the line before you install it to the gauge. Also, having air in the line makes no difference as it just pressurizes to the same level as the oil. In fact, some air in the line will act as a mini-accumulator--dampening any pulsations in the oil system.
Second: Either someone has installed a higher rate regulator spring in the oil pump or a higher pressure pump. It should cause you no problem except for using a little more fuel for the added work it is doing.
I see no symptoms in your original post that would indicate any problem whatsoever with the gauge. Rebuild/replace it if you want; but another gauge will almost surely do the same thing.
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Originally Posted by 7t1vette
i see no symptoms in your original post that would indicate any problem whatsoever with the gauge. Rebuild/replace it if you want; but another gauge will almost surely do the same thing.
