Tach problem
Old Nov 13, 2012 | 11:49 AM
power shift's Avatar
power shift
Default Tach problem
My 78 has had a lot of engine work through the years that I don't know what color is the tach wire. I have a light brown loose wire left. It has a complete MSD system in it and the tach just goes up slow and stops. I installed an auto meter 5 in tach with a MSD adaptor and it works fine but I'd also like the factory one to work too.
Old Nov 13, 2012 | 01:54 PM
AirborneSilva's Avatar
AirborneSilva
I do believe on my 76 it is light brown... Don't know if that helps.
Old Nov 13, 2012 | 03:25 PM
power shift
Thanks for the response but I've got the MSD so where do I put the light brown wire. I connected it to the MSD tach adapter but it didn't work.
Old Nov 13, 2012 | 03:36 PM
AirborneSilva
Do you have the tach filter?
Old Nov 14, 2012 | 12:09 PM
power shift
No filter. I tried to hook up the light brown wire to the MSD adapter but it didn't work. This car has been through 4 engines and 3 different ignition systems so I don't have a clue as to where to connect the wire.
Old Nov 14, 2012 | 07:43 PM
AirborneSilva
on mine that brown wire goes to a filter then to the negative side of the coil, mine's a 76 if that makes a difference but don't think it does... I have been told if you don't have a filter, or one that works, then your tach will not work.
Old Nov 15, 2012 | 12:13 PM
power shift
Thanks for your response. I'll pick one up and try it out.
Old Nov 15, 2012 | 01:05 PM
AirborneSilva
No problem, good luck
To Tach problem
