I have been checking some of the vendor websites and can't fine the hardtop vinyl replacement kits. I know I have seen them in the past - the right weight and texture vinyl already cut to fit. Just glue it on. Who makes/sells them?
thanks! I also see Willcox carries it (same part #) , but when I first saw the description, "Vinyl Hardtop Cover" I wasn't 100% sure what it was - thought it could have been a soft cover that you place over the vinyl hardtop.. like a car cover.
Willcox used to carry them. I was going to buy one to have as a back up but was talked out of it. That was at least a year ago when willcox carried them. Cant say about today.
Why were you talked out of it? I have ordered one. Quality and fit problems?
Paul, please let me know how the new material fits on your hardtop. I will be doing this pretty soon, and would like to know how easy it was.
Thanks!
Ben
Hi Paul,
No problem with the vinyl material for the way it fit to my knowledge. My top is in great shape but thought I would get one just to have. Willcox told me they'll have the top material around and more then likely wont run out. I've always had a back up on things I do.
They did tell me that the top material they sell is hard to tell from the original once installed.
I have no idea what glue is used to apply the top material.
Give them a call about the material. Sure they will help you out. Hope this helps.
Hi Paul,
Thanks! I ordered the vinyl from an Eckler's re-seller here in Ontario. That saves me the UPS/FedEx brokerage fees. The downside is that shipping is slow.
My installer knows the correct glue and techniques to get this job done right. He has done work for me before and is very talented.
I've had a hardtop on my '72 for 38 years now, and my recommendation would be to replace the weatherstripping that's between the top and the rear deck lid no matter what shape it looks like it's in. If it's collapsed or squished at all, you will end up ruining the paint on the deck lid. The vinyl strips that the vendors sell to protect the paint do a good job, too, but only if the weatherstripping is in excellent shape. Don't ask me how I know all this.
Duane
Duane
The weatherstripping seems to be in very nice condition. And now liberally coated with conditioner. But I hear what you are saying. I would imagine that tightening down the rear studs too aggressively can do harm. If I don't like how things sit in the spring when this project is due to go public I will order new CRC rubber.
Thanks!
Ben
Ben,
I would not try the vinyl job myself. It is pretty tricky business. I will leave that to a professional.
Did you get the part I sent to you?
Luckily, my neighbor did vinyl hardtops back in the 70's and he said we could do it together. As for the part yes I did get it. Thank you very much. I will let you know how my install goes if I decide to pull the trigger soon.
Glad you got that part! I sent by regular air mail from Canada and you never know.
Duane
Please, DO replace at least the rear weatherstripping when you restore this top. Even if it looks good to you when inspecting, the properties of the material are not what they used to be if not new.
As for deck paint damage from the top being torqued down too tight, realize also that if you don't tighen it down enough, it'll vibrate and rattle, causing a very annoying noise while it wrecks the paint.
Good luck with the rest of this project. I did mine last year (body color). Lots of work, lots of fun and a great looking outcome in the end. You're gonna love it.
All new hardware is here, plastic deck protector (sturdy but I may add black felt patterned to it given comments here), Al Knoch pre-cut vinyl cover, hardtop carrier, etc. I have an appointment with the vinyl installer next Monday. I may have myself a Christmas present?
The deck hold-down hardware is new. And the front latches have been refurbished. I hope the vinyl installation goes well. If not I will be very disappointed. I did move the SS trims a bit today and they do move. So that is encouraging!
It's going to look pretty sharp Paul.
Your gonna have nothing to do now until thaw though...
What kind of a job is it to remove that deflector you run anyway?
I'm going to put a new fuel filter in the carb so I'm hoping to stretch that out until March or so...
If you mean the Lexan Windjammer, that takes two minutes with two Allen screws. My 1974 is in commercial storage with the Haartz soft top up. The Windjammer is in the basement.
You are correct about nothing left to do....And that can be annoying: not using the VISA or PayPal for the coming months. But part of this little project was to be my Wife's Christmas present to me. So I hope it comes through. I have new weather stripping etc. to present to her on Christmas morning (for me). OK, that does sound bizarre. But strangely she accepts it. She really enjoys this car.
Watch that fuel filter replacement. But you know the 5/8" and 1" drill. Many people do not.
If you mean the Lexan Windjammer, that takes two minutes with two Allen screws....
Now all you need is one of those hoists set up in the garage
I've actually seen the short filter in the long carb more than once. Amazing how someone can take something out and put in a new one that's remarkably different and not notice.
Then again I always cut the filters open to see if/what crud might be in the gas / tank so maybe I just spend more time fondling them than most.
BTW, I was looking for an end of the season wrap-up from you and must have missed your post(?)
