Engine
Old Nov 14, 2012 | 05:10 PM
mk8035's Avatar
mk8035
Default Engine
What should i look for? Removed engine today. 350 First thing starter would not engage flexplate I think my my mechanic was drinking. There was water on the number 6 and 7 cylinder you can see the rust. There was also a little water in the oil pan.
Old Nov 14, 2012 | 05:16 PM
scottw's Avatar
scottw
Are you looking at rebuilding your engine? Was it already rebuilt and you are unhappy with the mechanic? Explain what you are trying to do and there will be plenty that can help.
A little water in the oil pan. Is that only water or coolant / water mix in the water?
Old Nov 14, 2012 | 05:20 PM
MrJlr's Avatar
MrJlr
Look for a crate engine...
Old Nov 14, 2012 | 05:27 PM
mk8035's Avatar
mk8035
Had one blow it up with a blower on it. Wife not Happy $$$$$$$$$$$$$$$$$$$$$$
It was suppose to be rebuilt already.
Old Nov 14, 2012 | 07:09 PM
joewill's Avatar
joewill
bad starter, bad flexplate, bad head gasket, crack in block or head...
what does your mechanic have to do with your question? we need more elaboration.
Old Nov 14, 2012 | 07:17 PM
mk8035's Avatar
mk8035
Fired the Mechanic never take my car to one again. So the simplest thing is to check the head gasket? And go from there?
Old Nov 14, 2012 | 07:25 PM
diehrd's Avatar
diehrd
Someone is drinking ,,, Sounds like a carb to pan crate replacement engine should cover all the issues you listed
Old Nov 14, 2012 | 10:48 PM
Sideways73's Avatar
Sideways73
??? the mechanic did what ?? lets start there.....
not the smartest on cars, but willing to dive in and try pretty much anything
Old Nov 15, 2012 | 09:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mk8035
...What should i look for?...
A couple of the How To Rebuild Your Small Blook Chevrolet books.
Old Nov 15, 2012 | 09:41 AM
mk8035's Avatar
mk8035
Doing it now. Crank still will not turn?
Old Nov 15, 2012 | 09:48 AM
RIO68's Avatar
RIO68
Looks like all you can do is lay it out on the table apart and start looking at what you have and decide from there. If experience is something you don't have as to rebuilding then looks like a crate engine is the best solution. My 2 cents
Old Nov 15, 2012 | 09:59 AM
keithinspace's Avatar
keithinspace
I don't know. Seems like there SHOULD be something recoverable there.
I'm currently rebuilding my engine. Acid dipped 4-bolt block is in great shape. Crank is in perfect shape. Rods and TRW mini-dome pistons are in great shape. New rod bolts and I'm in business!
New aluminum heads, new camshaft and valvetrain, and new clutch assembly.
I'm cleaning up and painting all the other bits. ~$3,500 and I'm going to have a SOLID 500 HP engine that is bulletproof to 6,000 RPM.
If your valves are in OK shape, you could get your heads touched up for $200 or so. If you're OK with your cam, lifters, and rockers, that would save money.
I bet you could get that engine back together in good shape for $2k. Or you could get a crate engine with ~425 HP for however much...$3k? $4k? Or you could "perk up" your engine for the same money.
Point is: GET AN ENGINE GUY. Not a mechanic. An engine guy. There IS a difference. And engine guy knows ENGINES and can get around the rest of the car.
If the guy owns a shop with 8 lifts and a brand new F250 with his phone number on the side, he's a mechanic. If the guy owns/drives 6 nostalgia dragsters and drives around a Buick Roadmaster because it rides like a dream and has a Corvette 350 in it, HE'S AN ENGINE GUY.
Old Nov 15, 2012 | 10:16 AM
mk8035's Avatar
mk8035
Got to do it myself dont trust any one. Just removed the heads and the two back pistons on both siges are covered in rust.
Old Nov 15, 2012 | 10:37 AM
keithinspace
I totally agree, Mr. MK8035. I'm doing 90% of the work myself. I was lucky enough to befriend the owner of the Speed Shop and he is working with me.
I completely disassembled, but gave him the opportunity to look at things at a certain point in the diassembly.
He told me what to do and what not to do.
He will probably assemble the rotating assembly WITH me in his shop.
For him to "stand behind" the engine, he has to be involved with the assembly, but he knows I'm into doing stuff myself.
Don't hand it to someone, but don't try to do it by yourself, either. There are lots and lots of things that you or I know nothing about that an engine builder can spot in a nano-second. Crack the yellow pages, find a small shop, and have a across-the-counter chat. Can't hurt.
Old Nov 15, 2012 | 11:02 AM
mk8035's Avatar
mk8035
Yep thats what i am going to do. Actually i have the whole car apart redoing all the wiring and defective parts. Paid 5,000 for this engine it is like i cant win but i wont give up. Wife says i am crazy
Old Nov 15, 2012 | 11:09 AM
Easy Mike's Avatar
Easy Mike
...Paid 5,000 for this engine...Wife says i am crazy...
Excuse me, but if you paid $5K for an inoperable smallblock Chevrolet engine without a C3 wrapped around it, I would have to agree with your wife.
Old Nov 15, 2012 | 01:53 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
Mike and I both agree with your wife....
Someone needs to stand behind it, either warranty from where it came from or the mechanic...
$5000 jeepers.....I have gone 12's with used parts I threw together in my barn
To Engine
Old Nov 15, 2012 | 05:19 PM
mk8035's Avatar
mk8035
My wife would like that. Now do i rebuild the old or just get another one?
Old Nov 15, 2012 | 08:23 PM
keithinspace
If you "get another one", it's not like you're getting a new block or anything...they're just reconstituting a core block and building an engine around it.
So...I'd think it odd not to work with what you have.
Old Nov 15, 2012 | 08:32 PM
Sunstroked's Avatar
Sunstroked
Here is what I would do. I would take the entire engine to a REPUTABLE engine machine shop. For a nominal charge they will inspect the engine and tell you exactly what you need to rebuild it. And give you an estimate, usually if you decide to rebuild, the inspection fee is waived. If it exceeds what you want to spend, then by all means look for a crate engine. You might save some cash going with the rebuild, you already have $5k in it,
