front spoiler
Old Nov 18, 2012 | 08:36 PM
AirborneSilva's Avatar
AirborneSilva
Default front spoiler
does anyone make a larger front spoiler to direct more air across the radiator? thanks
Old Nov 18, 2012 | 08:43 PM
bpassmore's Avatar
bpassmore
First make sure all the foam baffles and seals are in place. Missing these will let the air flow to pass around the radiator instead of through it.
Old Nov 18, 2012 | 08:49 PM
AirborneSilva
I do need to get the foam pieces, the ones on the side are old and am sure they have shrunk, the ones that go on top are gone but if I can get a spoiler that is longer to help direct more air across the radiator that would only help.
Old Nov 18, 2012 | 09:54 PM
oldalaskaman's Avatar
oldalaskaman
http://www.ecklerscorvette.com/corve...1973-1979.html
Old Nov 18, 2012 | 11:46 PM
REELAV8R's Avatar
REELAV8R
Cha-ching.
You can use pipe insulation foam around your radiator also. It works good and looks fine. The round grey stuff with a slit down the length.
Old Nov 19, 2012 | 04:44 AM
AirborneSilva
I'd like to see pictures of a 76 with that pace car spoiler on it.
Old Nov 19, 2012 | 04:45 AM
AirborneSilva
Originally Posted by REELAV8R
Cha-ching.
Yeah good idea, it would probably be nice and snug in there
Old Nov 19, 2012 | 05:06 AM
palmbeachvette76's Avatar
palmbeachvette76
My '76 has the one piece Pace Car from Ecklers. This was before I changed the front bumper cover to the 1980 style.
and with the new 1980 styled bumper
Old Nov 19, 2012 | 07:10 AM
AirborneSilva
Thanks for the pictures, I like that front bumper Do you have a side shot?
Old Nov 20, 2012 | 04:58 AM
palmbeachvette76
Old Nov 20, 2012 | 05:00 AM
AirborneSilva
Looks great, love the side pipes too thank you for the pic...
Old Nov 20, 2012 | 05:05 AM
palmbeachvette76
Anytime Air
Old Nov 20, 2012 | 05:12 AM
AirborneSilva
Is this the one you got?
If so then I'll put it on the list, can't get it now the Vette is in the shop getting the diff rebuilt.
Old Nov 20, 2012 | 05:16 AM
palmbeachvette76
Yes, that's the one. The only thing I had occur that I improved was the mounting on the outer portion where it meets the front wheel opening. On the highway at speeds above 60 the wind was pushing the spoiler into the tire. I added a self taping screw and washer below the top (highest) mount to prevent it from bending. Worked fine ever since. I think to be on the safe side I added a few more screws in between the factory locations along the curved portion since the underside was fine.
Old Nov 20, 2012 | 05:22 AM
AirborneSilva
Thanks again!
Old Nov 20, 2012 | 03:13 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
FWIW, when installing a functioning front air dam such as is the PC one, you should also install the rear spoiler to maintain both visual as well as aero balance at higher speeds. If you prefer, an '80-82 tail is a good option, tho the larger spoiler likely works better on pre-fastback C3's. My $.02
To front spoiler
