just got a 79...need some advice
Old Nov 23, 2012 | 07:55 PM
Vettehead- nj's Avatar
Vettehead- nj
Cruising
Default just got a 79...need some advice
Hey all,
I just got a 1979 l-82. i am having a slight issue with the door. when i bought the car the lock on the drivers side would only open from the outside. when i got it home i tried to lock it and it worked but now i cant open the door ( from inside or out) i know the common thing to do you be to take off the panel and take the lock apart but i cant remove the panel without opening the door.... any ideas for how to get the door open?
thanks
Old Nov 24, 2012 | 10:18 AM
24695bob's Avatar
24695bob
I'm NOT laughing BUT the panel can be removed without opening the door..it required me to "modify" a few screw drivers by bending them and destroying a few clips (easily replaced) Had to do this on a 72 ... not a 79 .but since I also own a 79 I think the 79 may actually be a little easier ...still not fun..
IF the window is UP you may be able to get a wire (rod) down inside and trip the release handle I tried but had no luck what so ever...
Bob G.
64 72 and 98 Convertibles
76 79 and an 88 35th ANC Coupes
Old Nov 24, 2012 | 11:45 AM
briankeery's Avatar
briankeery
Can you try to get some WD-40 into the lock and try to work your key back and forth?
To just got a 79...need some advice
