Sensitive horn on 79
Old Nov 24, 2012 | 05:39 PM
cb98coupe's Avatar
cb98coupe
Default Sensitive horn on 79
So , I picked up a 1978 anniversary model . I will post some pics soon . Anyway . When I turn the steering wheel the horn will honk . Seems to do it alot . I noticed that the horn button has alot of play . Possibly when I am turning the wheel the easy play is making the horn honk . I don't think there is a short . Is there a way to tighten this up ? Anyone know of this issue and point me in the right direction .As of now I disconnected the horns but don't want to leave it for long like this . Thanks .
Last edited by cb98coupe; Nov 24, 2012 at 10:18 PM. Reason: additional information.
Old Nov 25, 2012 | 09:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Remove the horn button and check to see whether the horn contact is loose. Shims for the horn contact are available if you need them.
The horn button should be tight and should not be moving around on you.
Old Dec 3, 2012 | 11:06 AM
cb98coupe's Avatar
cb98coupe
Does anyone know where to get the shims ? The horn button is very loose . Thanks
Old Dec 3, 2012 | 01:24 PM
Easy Mike's Avatar
Easy Mike
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Dec 3, 2012 | 11:00 PM
cb98coupe's Avatar
cb98coupe
Thanks , gonna order one up and get it installed when I bring it in next week for a tranny service . I really appreciate it . I have the horns disconected for the time being . I am new to the C3 section and really like my new ride .
thanks , Chris
Old Dec 4, 2012 | 11:18 AM
kschulen's Avatar
kschulen
I had a similar problem in my 79. If there are no shims for the horn contact, definitely put at least one in there to tighten that up.
My problem however was not with the shim, everything was tight. My problem was lower int he steering column. My horn honked when turning the wheel and moving the turn signal lever. The problem turned out to be the screw that puts tension on the turn signal lever just under the turn signal canceling cam. , that screw was touching the contact on the cam which would cause the horn to honk.
I ended up having to grind down that screw and now all is well
Old Dec 6, 2012 | 08:18 PM
cb98coupe's Avatar
cb98coupe
thanks guys
To Sensitive horn on 79
