View Poll Results: Which air cleaner looks better?
Edelbrock Pro-Flow
3
11.11%
Edelbrock 10" diameter
14
51.85%
Other, (please specify)
10
37.04%
Voters: 27. You may not vote on this poll
Air Cleaner Question
Old Nov 25, 2012 | 01:56 PM
htown81vette's Avatar
htown81vette
Default Air Cleaner Question
Easy question, which of these air cleaner looks better? Both are Edelbrock, and will fit under the hood of my '81 Vette w/ the RPM Air-Gap manifold. My old 14" drop base cleaner wont fit with the new manifold, so I have these 2 choices.
Old Nov 25, 2012 | 02:00 PM
htown81vette
Here are the pictures of each option:
Option 1:
Option 2:
Old Nov 25, 2012 | 03:38 PM
AdamMeh's Avatar
AdamMeh
Option 1 screams "1980's" to me, so I would pass on that version. One problem with that style is a single backfire and the foam element is toast.
Option 2 (I have a larger diameter version) is very overused. If it hadn't come with our car I wouldn't be using one. I'll be switching it out to a plain chrome lid with no branding, which given your valve covers (no branding) and how clean your engine is would be a better choice IMO.
Adam
Old Nov 25, 2012 | 04:51 PM
Heath66's Avatar
Heath66
I like option #1. It seems to fit the look better.
Old Nov 25, 2012 | 05:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
#1 looks like it belongs on some teenager's car.
#2 Looks undersized and restrictive.
What is the fitment issue with a proper size (14") dropped base filter?
Old Nov 25, 2012 | 06:21 PM
htown81vette
Here is one I'm very interested in, not sure if it will fit though...
htown81vette
Well, it is a 1981 vette That screams 1980's also
Old Nov 25, 2012 | 06:23 PM
AdamMeh's Avatar
AdamMeh
Very true... but his engine is pretty modern looking with those valve covers etc.
Sort of like wearing 20 year old shoes and a brand new suit.
Old Nov 25, 2012 | 07:17 PM
georgiaboy's Avatar
georgiaboy
Tell me about this one ...... I really like it and it looks like it would solve some hood clearance issues ............. I have a 78 with a GM 350 / 330 crate engine.
Old Nov 25, 2012 | 07:41 PM
spdrcr29's Avatar
spdrcr29
I would go for #2 if it were mine...
Old Nov 25, 2012 | 08:25 PM
htown81vette
I don't know that much about it other than it is made by Holley and goes for about 300 bucks. But looks really cool. My Dad had it on his '34 Ford custom show car. But from looking at it, it really looks like it will fit. I just wish I could find someone on here that has it so I can confirm. I guess I *could* be the guinea pig
Here it is on jegs.com:
http://www.jegs.com/i/Holley/510/642...oductId=743323
Old Nov 25, 2012 | 08:28 PM
htown81vette
Thanks!! And good point...
Old Nov 25, 2012 | 08:32 PM
htown81vette
The drop base interfered with the demon carb, otherwise it would fit (just barely).
Old Nov 25, 2012 | 09:45 PM
Ibanez540r's Avatar
Ibanez540r
NOT a fan of #1
Old Nov 25, 2012 | 10:29 PM
couperdecar's Avatar
couperdecar
Old Nov 25, 2012 | 11:43 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Option 1 is one of the worst air cleaners ever produced especially if it contains foam (most do) as it's a carb fire waiting to happen.
Old Nov 26, 2012 | 12:03 AM
3JsVette's Avatar
3JsVette
I'm not really crazy about either one. There are "spacers" available that go between the top of the carb and the base of the air cleaner. GM even used them on trucks with big blocks back in the day. Why not experiment with some cardboard (or something similar) and see how thick of a spacer you would need to clear the carb? Then you can use your 14" drop base. You can always go with a shorter air cleaner element (K&N builds elements to custom dimensions if need be) to make up the difference in hood clearence so everything fits. Just throwing that idea out there. It may or may not help.
To Air Cleaner Question
Old Nov 26, 2012 | 01:30 AM
scottyp99's Avatar
scottyp99
Yeah, so make it fit, that's all. Wait a minute.......this isn't about what will fit at all, is it? You want to be able to see the carb, don't you? I don't blame you, it's a cool looking carb!
What intake manifold are you running? performer RPM Airgap? I think a dropped base air cleaner with a 3" element will fit under the hood. And, I would bet 300 of your dollars that the Holley air cleaner will fit, too. The directions say to cut the carb stud 1 5/8" above the air ncleaner gasket on the flange, I think that should fit under the hood, barely. I think it's a little too wacky looking for my taste, but that's what makes the world go 'round. It'd be a boring world if we all liked the same things. I wonder if you can get bigger filter elements? they look kinda small.
Keep the shiny side up!
Scott
Old Nov 26, 2012 | 06:34 AM
htown81vette
Good idea, I'll give that a try..
Old Nov 26, 2012 | 06:36 AM
htown81vette
Yes, its the RPM air gap (polished version). And thanks!! I like the way the holley
a c looks, but parting with the $300 is the part that makes me sad, other wise it would be on there by now.
