View Poll Results : Which air cleaner looks better?
Edelbrock Pro-Flow
3
11.11%
Edelbrock 10" diameter
14
51.85%
Other, (please specify)
10
37.04%
Air Cleaner Question
Nov 26, 2012 | 07:09 AM
I have option #1 and like it so far. Had option #2 but with my new carb it wouldn't fit because it was hitting the throttle cable holder...
Nov 26, 2012 | 08:10 AM
If your willing to cut and weld, this will fit under the stock hood
Nov 26, 2012 | 09:41 AM
Quote:
Originally Posted by
77C34SPD
What do you have to cut and weld? I can do both...
Nov 26, 2012 | 11:25 AM
Here are some pics before final clean up.. If you have access to a tig welder will be much easier and nicer..I used mig with spool gun. None of the welding is visible..
bottom of the front, 1/2 inch lowered with piece welded in
Had to trim coil cover, notice the inner air cleaner base was raised even with filter boss
Nov 26, 2012 | 11:29 AM
side view
Nov 27, 2012 | 05:32 PM
Just bought this last night. Putting it on my 75 Vette 350cid L48. Looked good on my 58, a bit close on hood clearance tho.
Nov 27, 2012 | 05:34 PM
The holley Hi-Tek that is.
Nov 28, 2012 | 01:06 PM
Royal Canadian Navy
This is mine. The base plate does not need any holes cut or any other mod. Its sitting on top of a Holley 4150 DP/Weiand Team G intake under the stock hood.
Nov 28, 2012 | 01:28 PM
option 2, that's what I have
Nov 28, 2012 | 02:44 PM
option 3?
Nov 28, 2012 | 03:03 PM
resdoggie
That looks good, I like it. What brand is that?
Nov 28, 2012 | 04:17 PM
resdoggie
But will that work with an air gap intake?
Nov 28, 2012 | 05:31 PM
Royal Canadian Navy
77C34SPD
The carb height of the Team G is lower than the yours so probably not. But that's why I went with the Team G single plane. Works great.
Nov 28, 2012 | 05:34 PM
Royal Canadian Navy
htown81vette
Billet Specialties I think was the brand. Bought from Summit.
Nov 28, 2012 | 05:46 PM
resdoggie
Looks good. These type of filters really look good because you can actually see the carb and intake.
